Question about The Watches
How do I set an Azland KW0004GR watch without a user's manual?
This is an ASIN B01HGP8M9C model KW0004GR boy's water resistant watch. Can someone tell me how to set it or how to find the user's manual?
escapement
  • 2334 Answers
SOURCE: user manual
Try this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Posted on Mar 29, 2009
  • 73 Answers
SOURCE: set a watch
If you can tell me the model number and maker of the watch I can help you.
Posted on Jan 07, 2008
SOURCE: Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Posted on Nov 04, 2008
escapement
  • 2334 Answers
SOURCE: Guess Steel Water resistant is not water resistant!!!
Water resistant does not mean water proof. You should never wear this watch while bathing, swimming or in sauna.
Any watchmaker will be able to remove any condensation and dry out your watch - no matter you are in the U.S.A. or Romania.
Find your nearest watch repair shop and ask for help.
Rate, please.
Posted on Jul 20, 2009
escapement
  • 2334 Answers
SOURCE: I bought this watch and misplaced the manual for
Click on my profile (escapement), then click on Tips and Tricks. There you will find links for all watch manuals.Rate me, please.
Posted on Mar 18, 2010
I have a calypso watch (k5669/6 model) and I'm not sure how to change it to 12 hour. Can someone please help me??
Here is the link for the user manual which will tell you how to change time mode. Note you have to have the watch available to perform the download
Download the manual Calypso Watches
Aug 23, 2016 | Calypso Watches
I bought my relic watch last year around christmas time it claims on the back of my watch it is water resistant up to 165 meters i haven't even gone close to that depth for the past 3 months or so my...
The most common failure of a watch to be water resistant is caused by a faulty contact between the case at an opening around the glass, crown, or pushbutton and the opening's gasket. Worn or defective rubber O-rings are often a cause of failure. Condensation forming under the crystal of a watch following a sharp temperature change (a swim after a stretch in the sun, for example) tells you to have the watch checked without delay. This can be an indication of additional moisture elsewhere inside the case. It is also the only water-tightness check a consumer can perform.
Of course non-water-resistant watches don't contain the additional seals and gaskets found on water-resistant models. Consequently, moisture-laden air can easily enter the case. Once inside, a pronounced change in temperature may cause condensation to form under the crystal. Very little can be done to prevent this. A high-quality water-resistant watch, however, properly serviced and maintained, will be sealed to prevent internal water damage and will more than outlast an ordinary watch.
To keep the watch properly sealed, replace any defective parts , such as gaskets, crystals, and crowns. Water-resistant watches should be tested for case tightness at least once a year, as well as every time the watch is opened, such as when a battery is replaced.
Aug 26, 2010 | Relic Watches
I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Jun 27, 2010 | Watches
Looking for user guide for model 4511 Desert Falcon Zodiac watch
Clearly a screwdown crown is better for water resistance but most watches maintain a seal without it. I wouldn't test out the 100m claim but it should be safe in the pool.
Apr 29, 2010 | Watches
I need instructions how to set time on Tozai wrist watch. It has a "Bluelite" and "Lithium" Alarm Chronograph water resistant and electro-luminescent.
You can get a set of instructions from their web site (tissot.com).
At the bottom of the page there is a menu; select "warranty" and a number of alternative PDF files appear on the left.
If you can't see what you want, select "user manual" from the menu at the top and enter the details of your watch.
Choose the one that is suitable for your watch and download
Mar 03, 2010 | Tissot T-Touch T33759851
Can someone tell me the replacement battery to use in a Movado Junior Sport watch, model number 605987? Thanks, Ken Hayes
The replacement will most likely be a 364. Be careful replacing the battery in this particular movement. The battery straps and parts surrounding are thin and delicate. I would also recommend that you have the watch pressure tested to insure the watch has been resealed to be water resistant. High grade movements such as this are easier to maintain with proper care and battery placement than to repair.
Sep 17, 2009 | Watches
How do you set the time etc. for the casio edifice (100m water resist) wrist watch
send me your email and i can forward you the users manual!!
Apr 24, 2009 | Watches
How do i set the alarm on my oakley detonator
Visit rubensmenswear.com
Find watch selection and download user manual for your Detonator.
Download is located at the bottom of the watch list.
Dec 17, 2008 | Oakley Detonator OAK0530 Wrist Watch
Set a watch
Jan 06, 2008 | Watches
Watches Logo
1,305 people viewed this question
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
