Ematic esb112x blue tooth not working...hooked up many different phones to it and signal is coming to phone ..hooking up but no sound to speaker...speakers work with auxiliary hook up. any thing I can do to get it to hook up. Jim
    Habit-Forming:
  • 195 Answers
Try resetting the unit buy holding down the volume up and power button at the same time. It may work.
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Posted on Jan 06, 2017
  • 6 Answers
SOURCE: USB DURABRAND UC-280 SPEAKERS DO NOT WORK
I just bought them today they work fine. You do have to have a high speed 2.0 USB port to plug them into.
Posted on Sep 03, 2007
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Posted on Mar 07, 2008
SOURCE: Receiver Realistic STA 2700: no sound / signal argggh
Sounds like a power supply issue, maybe the transformer when bad, it may need replacing.
Posted on May 16, 2008
SOURCE: Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Posted on Jun 26, 2008
SOURCE: overload message
I had this problem yesterday. In my case the problem was the subwoofer connected in the power outlet in the back of the VSX. Switching to other power outlet solved the problem. So the tip is: check what is plugged on the VSX power outlet. In my case the sub probably was draining much energy and causing the overload in the receiver.
Posted on Dec 21, 2008
Bluetooth has power and buttons click when pushed, but does not respond.
I just got my blue tooth ear phone to work with my laptop, sounds like you want blue tooth car to pickup on your phone speech and sound. You probably have to enable blue tooth on your phone and connect to the bluetooth receiver in the car. Probably be good if blue tooth receiver is on so phone sees the signal, that's the way mine worked, it showed that device, I clicked it to connect. Hope that helps.
Jul 08, 2016 | 2008 Hyundai Veracruz
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Mar 22, 2016 | Ematic ESB212 Wireless SoundBar with...
Set up for Blue Tooth
Please specify your phone make or model
Jan 17, 2014 | 2013 Toyota Venza
How do i hook up my cell phone to the blue tooth
normally
settings
network connections
bluetooth
Mar 31, 2013 | Cell Phones
How to use blue tooth from the car
Your phone has to be capable of blue tooth.Go into menu on car and phone for blue tooth.Set the car to discover or your phone and the phone will say discoverable for 30 seconds then the car or phone will say pair enter number. This number usually is 0000 then the car will say LG or what ever type of phone you have and you are done every time you get into the car it will automatically sink with your phone as long as blue tooth is turned on in your phone. Any one hooking their phone to your car will be number 2 If they drive the car and you are not with them their phone will hook up. You can by house phones that do this. You come home lay your phone down and your in another room the cell phone rings. You can push the cell phone button on your house phone and answer it or make a call from it . It will ask you on the screen if you want to use the home phone or cell phone and it stores your contacts also. If this helps please rate it
Jan 04, 2012 | Cars & Trucks
Need bluethooth for sony vaio vgn-n365e laptop
WHen you say blue tooth do you mean you want to hook it up to your home wireless network? if so you can buy a USB blue tooth adaptor to run on your computer. IF it does not have a USB slot you willl have to buy a rs232 port with usb adaptor or blue tooth adaptor. There is a difference between a blue tooth that you hook up at your home and a blue tooth that you can connect anywhere on line, for instance verizon wireless has a large area to use a blue tooth connection to the net but it costs you money. With the verizon plan you can use te net anywhere you can get a signal just like a cell phone. the blue tooth will allow you to connect to unlocked services for instances many hotels and cafes have wireless acess for free all you do is connect it up. If you need more help let me know and I will be glad to tell you where you can buy it and how much it costs.
Nov 20, 2009 | Ovens
Hooking a Palm TX to internet on bluetooth cell phone
6620 blue tooth is supported on Palm TX. Im not sure about Gzone. It does have limitations to it when using you TX to connect to a bluetooth cell phone for data service.
You can try the GPRS cell phone setting and see if it recognizes it that way.
Oct 08, 2008 | Palm TX Handheld
Dont know how to work my blue tooth to my phone
You have to get the phone to recognise the bluetooth headset first. The manual should tell you how to do this. Normally you have to go into the bluetooth menu on the phone and get the phone to detect the headset, and then type in the pin code, normally 0000.
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
90 people viewed this question
 Grubhead
Grubhead
