Question about Cell Phones
How do I answer on my ear piece - Cell Phones
I have an audio technica ath-anc7b noise canceling headphone. There is a crackling sound when I tap lightly on the left hand side of the earphone. There may be something loose. How can I open the cas
I was researching a similar answer and discovered that the left side ear piece actually is actually held together with 3 torx screws that are visible upon removing the ear pad and the padding surrounding the driver. I haven't had a chance to attempt a fix yet but remove those screws and see if you can open the ear piece.
Oct 06, 2012 | Audio Technica ATH-ANC7B Headphones
Can't hear call from the ear piece only on speaker
There could be a Three problems. In all cases you have to get it serviced.. Cause no.1_ Your ear speaker has stop functioning. Cause No.2_ There could be a connection loss with ear speaker. Cause No.3_ IC which looks after ear speaker has stop functioning..
Hope this has helped you.. Please rate the answer. Thanks
Jun 23, 2010 | LG CU515 Cellular Phone
Hi, I Have a w995 & the ear piece volume is low.
check around the ear piece, make sure that rubber piece is there and properly placed around the ear piece.
Mar 29, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Ear piece volume not proper
try to change a new ear piece to make a good out of voice from your caller....
Mar 02, 2010 | Nokia E61i Cellular Phone
Is there an in car charger for a Jabra wep 470 handsfree ear piece
Yes there is. On eBay.
Click here:
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 06, 2010 | Jabra Bluetooth Headset with Adjustable...
When i use my ear piece it used to be perfect but
then there is a problem in phone so take to mecahnic
Jul 14, 2009 | Samsung SGH-J750 Cell Phone
I cannot hear the person on the other end but they can hear me
you ear piece may need to be replaced you should take the phone to a repair shop and have them replaced the ear piece or look at the old one for you.
Mar 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
Brought new phone and need to connect ear piece
You will need to pair it with your phone. first make sure the headset is off, then put the headset in pairing mode by pressing and holding the answer/end button until a solid blue light appears. then you will need to goto your cell phones bluetooth menu, turn your bluetooth on, then in your bluetooth menu you will need to add a new device or discover a new device depending on the type of cell phone you have. Your phone should find the jabra ear piece if it's in range of your cell phone and will ask if you want to pair with the device, after accepting confirm with the pin of 4 zero's.
Feb 16, 2009 | Jabra BT250 Consumer Headset
I can not hear anything from my caller
i think what you speak will be heard by the persons who call you ...
you cant hear there voice because there is some loose contact in the speaker(ear piece) or it is dead or broken ...
if you are good at opening the handset then open it and refit the ear piece speaker correctly or if there is a problem in the speaker then it can be solved by replacing it ...
if you no idea of opening then just visit the technician he will do it but he may take some service charge for that ..
but the ear piece speaker is not at all costly it is very cheaply available ...
check the call volume while on call once before you do the above ...
i am sure you will be able to play the music ... dont just get confused because there will be 2 speakers in the handset one is the ear piece speaker which is used to hear the calls and one more is the loud speaker from which the music,etc will be heard ...
thank you
Nov 08, 2008 | Nokia 5200 Cellular Phone
Plantronics Explorer Plantronics Explorer
That is the job of the ear piece to keep the device in the ear
Jun 19, 2008 | Plantronics Explorer 320 Headset
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
