Question about Food Mixers
Where to find 2219823b for KSCS25FKSS02
WP & KA said it no longer available. Parts site can't get it...Is any one out there has one to sell..????
Im tryin to find replacmet beaters for my mixer and everyone doesnt sell them where do i find them... Model numb is 23869239
That may be a Kenmore part if so Sears can replace the parts. Can't help anymore with out a little more info on the Makeer of the mixer
Sep 24, 2014 | Food Mixers
I plugged my 110v KG25H3XWH mixer into a 220v outlet via a voltage transformer and turned it on. It immediately sparked, popped, emitting a burnt smell and tripped the circuit breaker. Is it possible for...
First here is the link to a good suuplier with OEM parts for 110 and 220 volt http://www.appliancezone.com/SearchProducts.aspx?ID=9707627&x=12&y=7
you can change any KA mixer from 110 to 220 and 220 to 110, you need the armature stato phase control board and speed swith for eith conversion, the 220 madel number or 220 model has a letter in front of the ka which is the indicator for 220 volt go to http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 for a exploded parts list and part numbers look any where for a KA 220 volt model and you can find the same thing
Oct 04, 2013 | KitchenAid Food Mixers
Kitchenaid 4ksm900b
you have an internal gear problem if you continue to us it you can damage other gears and increase your repair parts needs. go here to get a parts list for your model and start the tear down to find the culprit
http://www.kitchenaid.com/customer-service/manuals/
then order your part from eBay or several site on the internet that sell KA parts like "Seneca River Trading or mending shed" then re-assemble. Parts will be anywhere from $6.00 to $20.00 USD. hope this helps
May 23, 2013 | Food Mixers
Replacement beaters West Bend 41036
The official parts source for West Bend advises that replacement parts for this product are no longer available.
You might try making an inquiry from this site; they also list these parts as no longer available, but perhaps they can reommend a compatible repalcement:
http://www.abtecparts.com/parts_enquiry.htm
Failing that suggest you take your old beaters to a small appliance repair shop and see if they can source a compatible replacement.
Feb 25, 2012 | West Bend 41036 Mixer
I have a Kenmore stand mixer that needs a new bowl. The mixer model # is 400.82573. The part number is 3140-012-0000
Sorry to say, the part is no longer available from the Sears parts site, and no substitute exists. Unless you can find a bowl from some other brand and model, or just a suitably-sized mixing bowl, you're out of luck.
Feb 13, 2011 | Kenmore Food Mixers
How do I get an owners manual for Kitchen Aid Ultra Power Model KSM90 stand mixer? I was given the used mixer and I do not know the frist thing about it.
Hi PASTYJOHN, it's very easy to download both the Owners Manual and Parts List manual for your KA mixer. You can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals& Guides> then enter the visitor type "Consumer" and enter the 6 character model number, in this case KSM90P, where you can choose one of the three size files under Owners Manuals (20). Since there are three versions - 191.99 KB, 2730.37 KB or 3230.97 KB, I would download all three and save the one you feel is best for your needs. Similarly, I would also download a parts list manual, too. Since the Parts List manuals are exactly the same you can choose any one of the 16 available to download and save.
Good luck, I hope this helps. Howard, Burke, VA, USA
If this solution was helpful, please rate it, thanks! - hslincoln
Feb 11, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
The insulation on the cord has deteriorated. Where can I get it replaced? Every site tells me to take it to Sears, but they won't repair it because I didn't buy it there.
Hi LOSCHR. If you are DITY type person, and feel adventurous, this is a very simple part replacement you can do yourself. I’ll assume your mixer is no longer under warranty.
Be sure you have the Parts List manual on hand. If you're lacking one, you can download it from the KA website http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW select Parts List (1) and then check to see it this matches your mixer model).
Turn to pages 6 & 7, titled: Motor And Control Parts for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 26 Power Cord, White (Part # 9701015). This is what you need to replace.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel replacing your power cord is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 16, 2009 | KitchenAid K45SS Classic Stand Mixer
WERE DO YIU GET TECH MANUAL
Hi, EMININES. KA does not provide a tech manual, per se. They do offer their mixer’s Owner’s Manual and Parts Manuals on line, and with the help of some very good web site links, you should be able to service your KA mixer. You can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P, and select the first file listed under Parts List (4) and then check to verify the illustrations match your mixer.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If this solution has helped you, please rate it. hslincoln
Dec 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KA Mod K5SS: no longer have variable speed; only 3 of the lowest
Hi. Go to mendingshed.com. Look up Kitchenaid Mixer Parts. Near the top of the page locate their FREE Kitchenaid Service Manual in Adobe format. Download it. This valuable document will help you with your troubleshooting of the speed control and anything else that needs fixing. This manual supports your K5SS. Mending Shed also carries Kitchenaid parts.
If you order parts from Kitchenaid, be prepared to wait at least a month for them to arrive!
If this solution has assisted you, please rate it. Good luck! ricardok45
May 01, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KichenAid K5SS Speed lever does not stay in ''off'' position. When the lever is placed in the off position it moves to speed 1 immediately.
Hi Burt. Go to mendingshed.com, look up kitchenaid mixer parts. Near the top of the page, locate the free kitchenaid service manual. Download this valuable manual, it will help you to diagnose and repair your mixer. Mending Shed also sells KA parts. If you order parts directly from kitchenaid be prepared to wait for at least a month for the parts to arrive.
Apr 14, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
