Green condition light flashing unit won't come on
2 Suggested Answers
  • 4736 Answers
SOURCE: flashing green light stays on,
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
Posted on May 06, 2011
Testimonial: "Your suggestion was right on. The unit is now working normally. Thank you."
Power light flashing green to red
Assuming the "squiggle line" is the Utility LED the unit has proper power. The light is steady green and not flashing, correct?
Have you reset the unit?
Try removing all but one attached device to verify it's not an overload condition.
A photo of the control panel would help.
Dec 23, 2012 | HP Compaq T1500 XR (204203003) UPS System
Paslode green light won't come on
if it flashes RED it usually means a bad or dead battery. If no light comes on then I would start looking at the contacts for corrosion and a loose connection on the circuit board/spark unit area. if no loose connection I would think the board is faulty
Feb 05, 2012 | Air Tools & Compressors
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Tv won;t turn on little green light flashes on power button
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | Televison & Video
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Deck top got pack up for new house and dose'nt won;t to cotackme on green light flashes in the back but no power to the s
prob:no power to mainboard
solution: Take cover off the side of unit find memory modules and reseat the mem sticks also find power harness usually clear or white w/ plug goin to main board unplug and reseat try to power up!
Apr 17, 2009 | Computers & Internet
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
