Question about Kenmore Dishwashers
Sears kenmore elite dishwasher does not drain completely
    Problem Solver:
  • 10 Answers
Look at the control panel and you will see a button that says "Cancel" and "Drain" Press the button after the wash cycle has completed and the machine will drain completely.
Posted on Jan 09, 2017
SOURCE: Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Posted on Aug 22, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
SOURCE: dishwasher not draining completely
I was having the same problem with water sitting at the bottom of my dish washer. I had recently installed a new garbage disposal when the problem started. You need to make sure that you knock out the inlet valve where the disposal drain line hooks up. If you have never hooked up a washer to your disposal, this piece will be in place. Stick a flat head screwdriver in where the drain hooks up and hit it with a hammer and the small plastic circle will pop out. The washer does not use any water when that is blocked and therefore will leave the old water to turn rancid...I hope this helps!
Posted on Sep 05, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Reset sequence for Sears Kenmore Elite 630.1630?
Unplug for 40 minutes to reset this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Blinking clean light, not completing cycles
some of the dishwasher have a device in them that you have to remove the container and clean it. mine is up side down cup that unscrews.
go to www.wikipedia.org
kenmore elite blink clean light
or go on to www.sears.com/service
talk to someone or look on line at
www.youtube.com/kenmore_elite_blinking_clean_light
see if anyone else had this issue
Mar 25, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Kenmore elite dishwasher: suds remain in bottom (ie don't drain completely)
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 15, 2011 | Kenmore Dishwashers
Kenmore elite dishwasher will not drain completely
heatman101
Aug 02, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Jan 20, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
My Sears Kenmore Elite will not drain
Pump might be restricted, with food particles, check it pump assembly from inside the cabinet, the drain hose also could be plugged, and finallly make sure that the impeller of the pump itself is working
Dec 23, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Dishwashers Logo
71 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
