Question about Refrigerators
I left the door open on my bekotzs490 it now seems to be slowly defrosting and is clmple5ly silent. What should I do?
2 Suggested Answers
  • 30 Answers
SOURCE: door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
Posted on May 19, 2010
DOOR LEFT OPEN ONE HOUR REFRI/FRE WON'T GET COLD
somehow may be stuck on ur defrost level cycle? u can check it by finding it usually inside the fridge at the top. a small plastic box like thingy. which if u look at it you will see a tiny whole which u can stick in a small philips screwdriver and turn slowly till u hear a clicking sound only 1 click not 2 or else u just turned on and off the defrost cycle. what you want to do is take it out of defrost cycle, so with screwdriver turn clockwise, good luck
Mar 12, 2015 | Refrigerators
Freezer working but refridgerator at room temp. Door seal hot.
either the evaporator coil is iced up which means the defrost heater is bad,the defrost control is bad or the damper vent door which throttles cold air in isn't opening fully from the freezer to refrige,the evaporator fan isn't running or if electronically operated the main board behind the unit can be bad on these as this board controls all electrical issues
Jun 20, 2010 | KitchenAid 19.7 Cu. Ft. Side-By-Side...
We left the door open over night,all defrosted,but seems to me that the temp is not going down,an hour gone since i've cleaned,any ideas?
some units take about 12/24 hours to settle down after a full defrost.keep doors closed and unit as empty as you can...
Jun 02, 2010 | Samsung RS2630SH Side by Side Refrigerator
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Defrost vent door wont open
sounds like you have a vaccum leak or a blockage in the blend door area of the HVAC system most of the doors are controlled by vacuum if not by vacuum on of the servo motors that control the blend door is not functuning properly. Hopr this is helpfull
Jan 17, 2009 | 1993 GMC Suburban
Dog left open and freezer not starting back to freeze
freezer condenser is frosted over. Open frezzer and defrost manuly. Open door and panel in back comes off with six screws.
Jun 17, 2008 | Samsung RS2630SH Side by Side Refrigerator
My Maytag frige model # MBB2556GES evaporator frosts over and shuts off air flow causing it to be too warm. This happens about every 6 weeks and I have to defrost. Can you tell me what causes this? The...
Defrost system problem related to defrost timer or heater circuit. Possible open defrost termination thermostat or open defrost heater. If timer is bad it will not go unto defrost automatically but can be manually started from the timer by rotating the clutch head screw slowly clockwise until you hear one click. If the system fails to restart after 30 minutes rotate slowly again until you hear another click and it should restart. If you had to rotate the timer the second time the problem is a bad defrost timer.
May 19, 2008 | Maytag Refrigerators
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
