Question about Cell Phones
RZ200.Code.D-08-224 - Cell Phones
Riso rz200ep error code d-13---9
http://printcopy.info/?l=en&mod=erc&brand=Riso&model=RZ200&code=D13-9
The link above states:
Code
D13-9
Description
The rear cover is opened (serviceman safety switch is OFF).
Riso RZ200 Error Codes
Mar 26, 2018 | Office Equipment & Supplies
Can a red drum for an RZ200 be converted to a black drum.
I am am currently not familiar with this model yet. But I have done such a procedure on other models already.
Please consider how to remove the unwanted colored ink. Do you want to dismantle and clean the whole drum mechanism? Or do it by printing several hundred (tousand) prints with high inkage? (You might discover some nice color effects.)
Some questions for you to make it clear: Does the black ink bottle fit in the color drum? Yes? Continue! Compare the PCB (unscrew the plastic housing) of a black drum with a color drum? Identical? Continue! Set DIP switches on PCB like the black drum. You are ready to use black ink!
Apr 27, 2011 | Riso Office Equipment & Supplies
How much would I pay for 2 x drums for a RZ200? Thanks
you can probably find them on ebay for about 3-4 hundred each.. new from riso they are very expensive..
Jun 22, 2009 | Riso RZ220 Duplicator
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
RISO RZ200
if show ERROR CODE D22-542 means the board in the drum have some problemif show D04-534 means you are using not original ink, but just press restart key is ok.
Apr 13, 2009 | Riso RZ220 Duplicator
I HAVE A PROBLEM WITH MY RISO RZ200.ON MY DISPLAY APPEAR AN ERROR CODE D22-542.IF I REMOVE THE CARTRIGE APPEAR D04-534.WHAT SHOUD I DO?
go into test mode..
turn off machine and turn it back on while holding down the left and right print position arrows.
if the error code shows up.. press the yellow reset button to clear it.. you will then see a number (firmware ver.) press the "C" button on the number pad..
you should then see the display all zeros "0000"
enter 890 and press start.
then when it beep press the "C" again enter 112
when it beeps again press and hold the yellow clear button and the machine will reboot...
i am sorry to say that if this did solve the problem you will need replacement parts or a new drum
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
