Please explain the control button on cm2021t - Washing Machines
Can someone please explain in English why the Philips 170S dispaly monitor's controls are locked and how can I unlock them....it seems my display has stopped working all togother a few days ago. Very...
The first requirement is that you must have video coming from your PC, then you have to press and hold for more than 10 seconds the "MENU (OK)" botton, this must unlock the OSD controls of your monitor.
Feb 10, 2011 | Philips 170S6FB/27 17" LCD Monitor
Please explain how to program buttons on the joystick.
Hi Asabin,
You need to install Logitech Gaming Software to configurate the button:
http://www.logitech.com/en-us/486/2967?softwareid=3916&osid=1&section=downloads
Same soft for Attack 2 and 3
Thanks and have a nice day
J -
Jun 06, 2010 | Logitech Attack 3 Joystick
I have a Duet washer, and the Control lock light is lite, how do I get it to turn off
Somewhere on the control panel under one of the buttons it will say hold for 3 or 5 seconds to lock or unlock control panel. You may have accidently locked panel while cleaning or some one held button for too long and panel locked. The control lock is there in case you want to prevent small children from turning on your washer. Just hold down button for a few seconds and light should go off.
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked--- how do I unlock?
Look at all the buttons on your control panel closely.you'll see a little padlock next to one of the buttons,hold button in 5-10 seconds control will unlock.hope this helps .please rate my response :)
Dec 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite HE 4t has a bulb illuminated on the front panel. The bulb is the "Control Locked" bulb and the washer does not work! Please help. I have tried unplugging it for awhile.
The reset or cancel button does not control the locking feature. Unplugging the appliance also will not reset it. The following link explains how to correct a control panel lock issue on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
The control panel lock is actually a designed safety feature that allows you to lock the control panel to keep small children from manipulating the controls. It can be inadvertently set by leaning against the control panel buttons, or following a power outage.
If you have questions, please let me know. I hope this helps you.
Oct 02, 2009 | Washing Machines
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet Control Locked button cycles on and off
Hi.
Please read the Fixya article below explaining how to fix the problems related to control lock on Whirlpool dryers and washers.
If the troubleshoot below does not work, then the problem may be a defective CCU.
The front light lit on my Whirlpool.
Regards.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have just purchased a Lexmark 2500. No where can we find an explanation of what each button on the top of the printer does. Can you please guide us?
You can access the publications for the Lexmark X2500 here: http://www.lexmark.com/publications/pdfs/2007/2500/en.html
Once in the User's Guide, look for the "Using the control panel buttons" topic. It explains the purpose of each button on the control panel.
Sep 23, 2008 | Lexmark Office Equipment & Supplies
WHIRLPOOL WASHER MODEL# GHW9100 LW2
Try pressing & holding the "End of Cycle Signal" button in for 3 seconds. This button is used to Lock/Unlock the front panel controls.
May 05, 2008 | Washing Machines
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
