Question about Tablets & eReaders
Why won't it take my WiFi password? - Tablets & eReaders
If I use my wifi password and decide I don't want this product how do I remove the password.
Tenda, So, it's time to remove a Wifi access point or password from your list. Here's how to do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android 101 How to forget Wifi network
How to Change Wifi Password from Phone or Any Device
How do change my wifi password
Apr 21, 2016 | Tablets & eReaders
My Kobo Arc 32, asked for a password, when I tried to try the WiFi. I don't remember setting a password. So, now it's asking for an guest password.
It is not the Kobo that has set the password, rather the router for the wifi that you are trying to connect to. You just need to know the password for the router to let you connect. If a router has no wifi password, it is considered unsecured and ANYONE can access it. So most all routers use password protection. If it is YOUR wifi system, and you no longer know the password, you can change it if you access the router setup for wireless and change the password. Be advised, however, that all devices that connect to the wifi will need to change their passwords as well or not be connected. If it is not your wifi you are trying to connect to, then you need to obtain the wifi password from that wifi system's administrator.
Nov 06, 2015 | Tablets & eReaders
My 7" DELAND DK701Q won't connect to the Internet thru wifi, what do I do?
Are you trying to connect to a wireless access point that's running WPA encryption and the tablet won't talk to a WPA access point?
Are you sure you have the password correct?
Mar 25, 2015 | Tablets & eReaders
My 10 in. tablet keeps going off wi fi and you can fix it but it still keeps going off.
Marie,
Make sure that you're attempting to connect to the right WiFi hotspot. The tablet may be attempting to connect to a WiFi signal that different from what you expect (a neighbor's, etc.).
Once you're certain that your accessing the intended WiFi signal, attempt your password again. Depending on model tablet, you may be able to keep the password displayed as you type for review before entering to connect. If not, carefully review each character on screen after touching each to see that it is correct (not capitalized, or number or symbol instead). Backspace as needed to make corrections as needed.
After seeing that the WiFi password is being sent properly to the intended WiFi signal, you will connect.
Feb 05, 2015 | Tablets & eReaders
How do I enter WiFi security key AXESS TA2513-10WT 10-Inch Dual Core,Tablet Rockchip 3066 CPU with Android 4.2 Jelly Bean
First of all, you must have the password which is set for your home WIFI. You can't do anything without it. Assuming you got the password, Go to tablet's Settings, turn on WIFI. When your WIFI router is displayed in the list, select it and you will be prompted for the password. Enter the password and click Connect. When you see Connected, it's done.
Jan 10, 2015 | Tablets & eReaders
I do not have a password to get on the wifi
if you are paying for wifi, you have a password. if you are using someone elses wifi you need their password.
Nov 05, 2014 | Tablets & eReaders
Kindle won't connect to wi-fi network
well maybe did you change your wifi password because that happend to me and then i rembered i changed the password for my wifi i hope this helped if not im sorry .
Dec 25, 2012 | Amazon Kindle Fire HD
My ipad wont let me do anything because it is asking for the password for the hotmail account
My ipad is on and it won't do anything. When you touch the screen to go into emails or anything else, even to turn it off it won't do anything.
Sep 01, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
23 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
