Question about Microsoft Xbox 360 Console
My xbox will not power on even though the ac adapter light is on.
The power light on the adapter is lit up but the console will not come on at all. Everything seems to be connected well. Please help asap. I'm dying.
  • 22 Answers
What colour is the powerlight on the adapter?
Green when the x360 is on
Orange when the x360 is off
Red when your power brick is broken
If you have not already done it I would try taking every cable out of the x360 and replugging it up from scratch (including the HDD if you have one).
Hope this helps.
Posted on Jul 21, 2009
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
My xbox 360 doesent what to turn on
if your are getting red lights, search for rrod on xbox or if its not that then its a faulty ac adapter
Jan 13, 2012 | Microsoft Xbox 360 Elite Console
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
My x box 360 will not turn on & the ac adapter box light is lit up red
If you are getting a red light on the A/C adapter then your adapter has gone bad and you need to get a new one.
Dec 22, 2010 | Microsoft Xbox 360 Console
My XBox 360 won't turn on.
try pressing the power button dnt just plug it in u ****
Jan 01, 2010 | Microsoft Xbox 360 Console
Wii will not turn on even though it has power and everything is connected. Help?
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 09, 2009 | Nintendo Wii Console
Plugged in powerless 360
The power adapter would have gone green when it was working normlly, its what it does, you need to replace the power adapter 'brick' as it is either faulty or was over heated due to travel. Good luck.
Nov 06, 2009 | Microsoft Xbox 360 Console
AC power adapter light is red what to do?
the power supply is already busted
you need to call xbox 18004699269
if you purchased the xbox within 90 days, then they can have your power supply replaced
if not you need to buy a new one
Jan 19, 2009 | Microsoft Xbox 360 Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
Three red lights come up when i turn my xbox 360 on
Hey dead end,
While this may be an indicator that something is wrong with your XBox 360, there are a couple of steps that you can take before seeking additional assistance.
According to information provided by the manufacturer, the light on your XBox 360's power supply should still light up green even when the console has encountered a three red light problem. If the light on the power supply isn't green, you will want to take different actions based on what color is displayed. If this light is red, the AC adaptor may either be defective or has recently overheated. If the light is orange, you may need to double-check all cable connections are secure. If the light on the AC adaptor isn't lit, the AC adaptor may need to be replaced.
Alternatively, you may want to try turning the XBox 360 off, then pressing the power button again roughly 10-15 seconds later. If the unit powers on normally and the three red lights disappear, the system may simply have needed to be reset.
Should the problem still persist, you may need to speak directly with Microsoft for further assistance. You can reach Microsoft's toll-free XBox support hotline at 800-4MY-XBOX (800-469-9269), or you can always request service through the XBox website:
http://www.xbox.com/en-US/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 24, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
