Question about Kitchen Appliances - Others
Indoor turkey fryer will not reach 350 degrees even though the green light indicating it is ready comes on. Any suggestions?
bigg t
  • 640 Answers
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Posted on Nov 11, 2007
  • 81 Answers
SOURCE: flame not hot enough
Replace the t-stat.
Posted on Jul 25, 2009
SOURCE: my superior deep fryer turns off including the
HEY, MY NAME IS KEVIN AND IM IN THE RESTAURANT BUSINESS AS WELL. IVE HAD THAT SAME PROBLEM,THE FIX IS TO REPLACE THE THERMO COUPLER. PART COST ABOUT 40.00 - 50.00 BUCKS DEPENDING WHERE U FIND IT. ANY QUESTIONS UFEEL FREE TO EMAIL ME. KHOFKIN@COASTALNOW.NET
Posted on Jan 13, 2010
kebah
  • 683 Answers
SOURCE: czf625 deep fryer wont heat.green
hi limit device possibly tripped off. look for a reset button, usually located at the back of the unit and reset it.
Posted on Mar 31, 2011
woobie dog
  • 1273 Answers
SOURCE: my brinkmann turkey fryer doesnt get up to boiling temp
Hi Larry, W/D here. Just got your question so I'm a bit late in getting back to you......
The amount of heat delivered at the burner is dependent on a number of things, and we'll take them in the order of most likely:
1st, The gas tip must be clear. It's possible for critters to build nests in the gas delivery piping that can plug either the gas delivery port or the air side of the mixing venturi; both will give you a reduction in BTU's. Compressed air can be used to blow out the air side of the venturi. The orifice for tha gas can be cleaned with a thin wire, or use a tip cleaner, available at a welding supply store. These are inexpensive.
2nd, The burner proper can become plugged at the ports where the mixed gas/air combusts. These can be cleaned with a small drill bit,sized to the holes, and just passed back and forth to clean them out. Compressed air works well to remove any particles remaining.
3rd, The regulator may be defective. If this is the case, you'll need to replace it as it contains no user serviceable parts.
4th, the in-line regulating valve may be sticking in the partially open position. This is difficult to diagnose, however, and is more of an assumption, after all other causes are eliminated. The cure for this is replacement also.
Hope that this was helpful to you.
Best regards, --W/D--
Posted on Nov 04, 2011
Why wont the skin get crispy in the Butterball turkey fryer. We have tried everything.
element isn't getting hot enough. maybe only heating half way. need to replace element and or controller temp inside without food should reach 425 deg.
Nov 02, 2016 | Masterbuilt BUTTERBALL Indoor Electric...
Why won't it turn on?
How to fry a Turkey - Butterball Indoor Electric Turkey Fryer ...
? 8:18
https://www.youtube.com/watch?v=PsAm5jGkOck
Nov 11, 2013 - Uploaded by therealcobraburnout
Butterball Indoor turkey fryer set up and first use. ... In case anyone trips on the cord, the whole fryer won't get knocked over..... well it holds 20lb bird, so you might be able to do maybe to smaller 7lb ones .... Just remember the oil will turn rancid in about 6 months once opened depending on how you store it ...
Butterball Indoor Electric Turkey Fryer - YouTube
? 2:35
https://www.youtube.com/watch?v=LJc8gf2QlG8
Nov 7, 2010 - Uploaded by tulwave
For More On Butterball Indoor Electric Turkey Fryer visit: ... Buy one and try it and i bet you won't be so negative. This thing works great for all ... I usually calculate 3
Dec 25, 2015 | Masterbuilt Butterball Electric 20 lb....
I have a Butterball indoor turkey fryer that lost power and the red light went off, is there a reset button on the fryer
There is a thermal cutoff near the heating element just like all appliances that make heat. It's supposed to stop a house fire but makes these appliance companies a lot of money.
Nov 28, 2013 | Masterbuilt Butterball Professional Series...
I have a Butterball Electric Turkey Fryer that heated up but when I placed the turkey in the fryer the red indicator went off and it lost power , is there a reset button on the fryer
All appliances that produce heat have a thermal cutoff inside to prevent a fire or meltdown. It's a shame they make them so fragile that it may ruin your special occasion. If you cross the wires on the sensor it may run forever but might be a fire hazzard.
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
Fryer overflows often, turned thermostat down from 350 to approx 340 but food does not cook then. could the thermostat be bad? 10 degrees should not make that much difference.
Does the fryer have a" temperature reached light"? If so switch the fryer on and with the thermostat dial starting at its lowest setting increase the temperature setting in small increments. When the light indicates temperature reached, increase the thermostat dial temperature. Continue until maximum temperature reached.
If (starting from cold) the temerature reached light only shows when high up on the thermostats temperature scale, then unfortunately the thermostat needs replacing.
Hope this helps.
Mar 04, 2011 | Dean D50G-C Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Sep 14, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Appliances - Others Logo
65 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
