Question about Bosch Washing Machines
My Bosch washing machine only half spins the clothes even in a very light load.
SOURCE: indesit W93 washing machine
We have W124, it allmost completed renewed inside. Thanks 3 years warranty and new service engineer, motor was changed and then all problems disappeared.
Posted on May 01, 2007
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
  • 130 Answers
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Posted on Feb 16, 2009
  • 103 Answers
SOURCE: CMD 126 candy washing machine struggles to spin even at low load
hi your balt is sliping or your ford geers are ded
Posted on Apr 05, 2009
Washing Machine will not spinn
Try to check the drain pump.
Jan 14, 2014 | Bosch Washing Machines
My bosch exclusiv washing machine which is 8 years old has stopped spinning the clothes, they come out soaking wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 26, 2011 | Washing Machines
Won't spin water from clothing
heatman101
Apr 17, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
It makes a squelling sound b-4 ging into the spin cycle. The clothes are not spun out very wet. This is the same without adding soap. I thought that was the problem so I rewash the clothes and the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
My bosch front loading washer on the small cycles will not spin the water out of the clothes..why?
Does it sound like the machine is spinning as fast as on longer cycles?Some machines run a slower spin speed on small cycles which can leave clothes wetter than normal. I've got this on mine and all I do is when the wash has finished I change over to the fast spin only program which then takes it to it's highest spin speed.
Jan 25, 2010 | Bosch Washing Machines
Bosch washing machine wont distribute clothes properly before going into spin
1st any washing m/c distribute clothes properly by reach to final spin speed gradually not abrubt so if your drum reach this speed suddenly so it will not distribute clothes properly >
2nd you need to but clothes one by one and must be correct weight not exceed>
so it is clear now i think
thankyou
Jul 09, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Apr 14, 2007 | Haier XQJ50-31 Top Load Washer
Washing Machines Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
