Question about Ricoh Great Condition Aficio Mp C3500 Photocopier Low Counter
How do I recover all the functions on address book on a printer Ricoh MP C3500. for some reason the file storage function it's been deleted and cannot use the scanner to save on file
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
bowdo
  • 78 Answers
SOURCE: Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Posted on Mar 19, 2008
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
FixinFax
  • 3085 Answers
SOURCE: trying to connect my ricoh aficio mp 2000 scanner to my computer
You can't do it that way, you need to connect with a parallel printer cable or a USB A to B Cable.
Posted on Aug 14, 2009
  • 377 Answers
SOURCE: how to install ricoh aficio
if you have user manual read it
do you have driver cd?
In most cases you will find that the Windows drivers found here are "self-extracting" (.exe) archives. Click the desired file. When prompted, we recommend setting the destination to your desktop. Create a new folder and move the archive into it. Click the file, it will then extract the software and related files inside of your new folder automatically. Alternately you may extract or move these files to a floppy disk. Please note that these files will only self-extract if executed from Windows. After extracting the files to a disk or a special directory, you should look for the installation program which is usually called "setup.exe" or "install.exe", click it to begin installation. If neither of these files are present, you should look for a text file containing special instructions called "Readme.txt" or something similar.
Sometimes there is no installation program because you must install your driver via the Windows "Add Printer" function. Instructions for installing printers can be found in the Windows help file.
Our Macintosh Archives are also self-extracting archives. These files should be downloaded and then executed. The installer will be present on the desktop when done. Click the installer and follow the instructions to install.
Types of Printer Drivers:
  • PCL5e Driver - Technically, the PCL5e has been superceded by PCL6, however, we make this driver available because the layout of some documents may be altered if they are originally created for a PCL5 compliant printer, but are printed using PCL6. PCL6 Driver - PCL6 is a good general purpose text / graphics driver. Ideal for Spreadsheets, Word Processing and Database printouts. It features superior graphics handling, although graphically better than the PCL5e driver it's speed is typically slower.
  • PS3 Driver - The Adobe Postscript Driver is generally superior to all, but it requires a Postscript compatable printer and can be a little more complex to install.
  • IPDL-C Driver - This is a color printer driver designed specifically for optimal perfomance under Windows.
Posted on Aug 31, 2010
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Hello, what is the procedure for managing user accounts through the Web Monitor
web monitor after logging in click on address book then add people and functions and there code to use. or click on change if all ready added to system.
Aug 27, 2014 | Ricoh Aficio Mp 3352 B&w Copier
How to delete an email address from Ricoh Aficio MP 4000
user tool, system settings, admin tools, address book management, delete selected users.
Jul 03, 2014 | Ricoh Aficio GX5050 GelSprinter InkJet
How to delete an email address (destination) from Ricoh Aficio MP 4001
Open the web click the top box and make it "blue" by clicking on it (the box with the the www.)and type the IP address into it, click enter. On the web image monitor page sighn in an admin no pass word (upper right) and click address book and you will be able to do it. - Carl
Apr 01, 2014 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh Aficio MP C6000 Printer Offline
check weather u have connected all cables properly
then check for your printer driver
after checking if everything is proper then right click on mycomputer select manage then serch for the installed driver then right click on pirticular driver go to properties then select driver tab then select rollback option if this dosent works then go to control pannel then go to printer n scanner option delet the installed printer and add it again
Jul 02, 2012 | Ricoh Aficio MP-C6000
We have a RIOCH Aficio MP C3500 PCL 5c copier/scanner etc.. We are trying to update the programmed email addresses (new employee) for sending scanned files. We don't seem to have a How-To manual. Can we...
Go to Ricoh website click support tab and do a search or press user tools/counter then system tab then administratior tab then address book new user program then enter name then email tab and under protection tab select sener too and save it.
Jan 12, 2018 | Ricoh Office Equipment & Supplies
How to delete an email address on the ricoh aticio mp c5000?
Go to system tools. Admistration tools. manage addresses. select delete then the address you choose to delete.
Nov 29, 2010 | Ricoh Aficio GX5050 GelSprinter InkJet
Mar 26, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Mar 26, 2009 | Ricoh FT5832 Copier
Ricoh Great Condition Aficio Mp C3500 Photocopier Low Counter Logo
64 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
