I have an NX DVD player that is stuck in Standby mode. How do I get it functional again?
Matteh
  • 83 Answers
SOURCE: standby mode on dvd player
My friend had this same problem, but I don't think it say sony, You need to check in back of t.v. and dvd player for loose or unplugged cords.
Posted on Nov 29, 2007
  • 7 Answers
SOURCE: stuck on standby
if you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Posted on Dec 31, 2007
  • 56 Answers
SOURCE: DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
Posted on Jan 22, 2008
SOURCE: Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Posted on May 15, 2008
SOURCE: dvd player stuck in progressive mode
My brother came over to "help" me and we put on the progressive scan...then no picture and you can't see the menu to change. DO NOT use the solution noted here suggesting holding the stop button - this puts on the child lock.
Open the door on the front of the unit; push the DVD button; then push and hold pause button for 5 seconds or more. And progressive scan light will turn off and your picture will reappear!
Thank goodness...I was thinking my brother would be buying a DVD player - hahaha.
Posted on Dec 26, 2008
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
Stuck on standby mode I have unpluged and it still is stuck on standby
It sounds like power supply problem, I have found that sometimes the main filter capacitor opens causing the machine to fail. It will take a professional to determine if that is the case or there is something else wrong.
Dec 28, 2010 | Memorex MVD2042 DVD Player
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 28, 2008 | JVC XV-523 DVD Player
Stuck in Standby
Apr 05, 2008 | Memorex MVD2042 DVD Player
Standby mode on dvd player
Has it recently been zapped by lightning? Ive never heard of this happening but i can tell you its not a problem you can fix. I suggest getting your money back or exchanging it for a new one.
Nov 29, 2007 | Sony DVP-NS400D DVD Player
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
