Widl 102 not drying after wash cycle
My machine will wash and sometimes spin but will not dry any more. Not even a single item.
  • 96 Answers
SOURCE: E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Posted on Mar 12, 2008
  • 78 Answers
SOURCE: Takes two cycles to dry anything - even on High
first, check your breakers for the dryer. turn them all the way off and then back on. if it still doesn't work right, it needs to have all the lint cleaned out of the exhaust hose, and then the inside needs to be cleaned and the heating coil examined for damage.
Posted on Apr 29, 2008
  • 351 Answers
SOURCE: hoover washing machine 550mb keep
Hi are the clothes tangled up around the agitator if so the gearbox may be faulty or the brake may be worn,is it washing in both directions
Posted on Oct 09, 2008
onthejob5130
  • 640 Answers
SOURCE: LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Posted on Dec 25, 2008
heatman101
  • 43501 Answers
SOURCE: my washing machines spin cycle is not spinning the
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 08, 2010
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
My washing machine does not spin the clothes dry-clothes are soggy
Was your load a single item or many over full. Many washer will quit so you can rearrange the items so it can spin balanced. The machine will try 10 times to balance the load , if it can;t do it it turns off and waits for you to do it.
Mar 14, 2015 | Maytag Washing Machines
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Items not dry enough after spin cycle, some water remains in machine
This is normal. It depends on a number of factors, including the type and volume of clothing you are trying to wash. Usually, it is not a machine issue.
Dec 06, 2013 | GE Washing Machines
How do I machine wash my futon cover?
You should wash your futon cover separately from other items. You need to ensure there is room in the machine for it. Avoid using detergents containing bleach. Wash the cover using the cold wash/cold rinse cycle (unless label inscription suggests otherwise). After the wash cycle is complete, you can put the cover in the dryer and tumble dry on a low-heat setting. I like to remove the cover halfway through the drying cycle to flip it to ensure that it dries evenly.
Aug 01, 2012 | Furniture
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Kenmore 90 series
you can look at the water pump inlet and outlet hoses. sometimes socks and other small items would be sucked in and blocked the water from going out.
another theory would be the clutch on the spin cycle is slipping that is why the drum is not spinning as fast as it should.
tnx 4 using fixya,
drcool
Sep 02, 2008 | Kenmore 15864/15862 Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
