I've filled in my paper application card. What do I do next?
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
Hi, I've got a 5500 designjet and when I print, after cutting paper, the printer reboot and after the initialization, the I/O card doesn't work. After that, I switch off than on and the problems...
It sounds like a bad JetDirect network interface card.
Turn the plotter off, remove the JetDirect card and see if it prints an internal test page without rebooting.
If it prints OK, turn off and reinstall the JetDirect card and see if it prints the same internal page OK.
If it prints OK both ways, you may have a bad Main PCA.
Jun 15, 2011 | HP DesignJet 5500PS InkJet Printer
Dear Sir, My HTC Smart is super slow & i sometime even can't send out masseges... i never install anything or use any SD Card... but i don't want to reinstall / reformat the whole phone....
With the Android OS, it is common that apps remain open in the background. Applications inclue your Messenger, Browser, Music, etc. (Not just the applications you download from the Market). I advise that you download a Task Manager from the Market. These can be found for free. Also, with Android always updating the OS, it fills a lot of memory on your phone. Installing a small SD card may be helpful for speed.
Jun 01, 2011 | HTC Touch P3450 Smartphone
I need to fill out a application online and submit it but i dont know how
Go to the web-page that contains the application.
Read the prompts for each field.
Fill-in the field.
Skip to the next field.
Fill-in the field.
Repeat for each field.
Click "SUBMIT".
Oct 27, 2009 | Computers & Internet
Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Jun 02, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Borderless printing kodak 5500, clear coating business cards
The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
  1. Click File , then Page Setup .
  2. In the Page Setup dialog box, click the Paper tab.
  3. Under Paper Size, select the appropriate borderless paper size.
To select borderless printing in the printer driver, follow the steps below.
  1. In the application, click File , and then click Print .
  2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
  3. Select the appropriate borderless paper size.
HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer issue...:(
Hi MaCaTa2,
It can be frustrating when things aren't going smoothly.
Sounds like you're wasting a lot of dye film and cards too!
What program are you printing the badges from?
You have a very 'paper' size with this type of printer.
If you select 'Magicard Printer Series' as the printer, you will then see a special paper size called 'CR80 Edge To Edge'. This is basically the size of a credit card. (2 1/8 x 3 3/8" (54 x 85.6mm). Check your font sizes are not too big. Any text printed on the back of the card is on page 2 of 2 (on the Tango model, a Rio would feed a second card).
Experiment with an application like MS Word, where you can clearly see the 'pages'.
Create a new word document, straight away go to 'File, Print', select 'Magicard Printer Series' from the printers list, then 'Close' (not 'Print'). Next, go to 'File', 'Page Setup', for the paper size choose 'CR80 Edge to Edge', set all the margins to '0' (this is a 'full bleed' printer.
You will now see a credit card size page to work on. If you fill this page (or insert a page break), you continue onto page 2 (the card back - only available on Tango).
I hope this helps.
Jul 01, 2008 | Magicard Tango 2 Printer
22 people viewed this question
