Question about Garden
Where do the petrol pipes go on my qulacast chainsaw pc40?
Where can i get a users manual from for the pc40 chainsaw
Hi Michaela:
Chain saw manuals can be quite similar.
Here's a link to an excellent one that should give you most of the information that you need.
Oct 19, 2015 | Garden
Where ?
Hi this should be a good link:
First two/three pages are in german, then the Qualcast manual is below :-)
May 13, 2014 | Garden
Holden barina carburettor problems
feed line blocked from petrol tank test to see if petrol is coming through , replace feed pipe also check carb float chamber needle could be bent thats why its not drawing petrol through hope this helps
Feb 07, 2014 | Garden
Chain replacement on qualcast pc40 chainsaw
Follow the instruction in owners manual page 8 click link belowchain replacement
click here page 8
Nov 20, 2013 | Garden
Qualcast petrol chainsaw manual Pc40
where can i get a manual for my qualcast pc40 chainsaw
Jul 27, 2013 | Garden
I have poulan pro 16" the fuel line was decayed
sounds to me that the carb is dirty you need to disconnect the fuel lines and unscrew it from the chainsaw then unscrew the bottom carefully blow through the intake and exit pipes they should be clear if not then you can use a thin piece of wire to unblock them replace the bottom and re attach the carb push the bulb on the bottom and it should fill with petrol pump it a few times then try starting the chainsaw it should start
hope this helps
Feb 26, 2011 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Not getting petrol through to the carburetor, I
I have a parts manual you can have a copy, can you tell me what the gas mixture for the Oleo Mac 234f, 25:1 or 50:1
Apr 01, 2009 | Garden
Leaking petrol
Hi bob
Below the carb there are towards the cilinder:a gasket,a plastik suport and another gasket.Check the gaskets from there.Also the 2 bolts of the carb should to be tightened.
cheers savumihai71
Dec 13, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
