Question about Xerox Office Equipment & Supplies
XEROX 260 Fiery Display FF then Computer & Printer Not Connected.
  • 2072 Answers
SOURCE: Xerox Fiery Xp12 - Problem (INVALID LICENCE) apears on the screen
You will need to use what came with your machine.
The note from Xerox states this.
NOTE: You will need the Fiery Restore / Update Server Software CD and the User Documentation v2.0 CD that came with your EX12 v2.0 Software
And here is the loading process
  1. Visually check to make sure the Fiery LCD is at the Idle screen before you proceed. This will make sure the Fiery is not in use.
  2. Insert the Fiery Restore / Update Server Software CD into the Fiery EX12.
  3. Press [Menu] button on the Fiery Server.
  4. Press the [Down arrow] button.
  5. Press the [Shut Down] button.
  6. Press the [Reboot System] button. The message 'Rebooting System' will display and disappear after a few moments. The Fiery Server will reboot and complete internal testing. The Restore / Update CD menu will be displayed.
    NOTE: Ignore the message 'It's now safe to power off the system'.
  7. Press the [Up arrow] or [Down arrow] button to scroll to 'Restore System' so this is highlighted. Press the [OK] button. The 'All data will be Deleted. Continue?' message will be displayed.
  8. Press the [Up arrow] or [Down arrow] button to scroll to 'Yes' so this is highlighted. Press the [OK] button. The 'Restoring System...' message will be displayed.
    NOTE: The System Restore will take approximately 7 minutes, during this time the message 'Restoring System...' will continue to be displayed.
  9. Press the [OK] button when the 'Restore Complete!' message is displayed.
  10. Press the [Up arrow] or [Down arrow] button to scroll to 'Exit' so this is highlighted. Press the [OK] button.
  11. Remove Fiery Restore / Update Server Software CD from the EX12.
  12. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
    NOTE: Wait 10 seconds before powering ON.
  13. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  14. The EX12 will prompt you to insert the User Documentation CD. Insert the CD and the Fiery will continue with the process. When the process is complete, the Fiery LCD will display the message 'Please remove CD'.
  15. Remove the User Documentation CD
  16. Power OFF the Fiery Server. The power switch is located on the rear of the server, above the power cord.
  17. Power ON the Fiery Server. The Fiery Server will boot and complete a self-test.
  18. Using the Configuration Report as reference, re-enter the network settings on the EX12.
  19. Install any required patches, as needed. Refer to the Updated Information section on the Configuration Report.
  20. If needed, restore any data that you previously archived. See the Related Items.
Posted on Jan 10, 2008
  • 62 Answers
SOURCE: Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Posted on Jan 18, 2009
  • 111 Answers
SOURCE: I am trying to connect xerox dc 12 Fiery x12 to my window vista?
you need to download/install new drivers -
Posted on Mar 21, 2009
SOURCE: i have a fiery print server connected to a xerox
i ended up having to call xerox to come look at it and there was a sensor that was not functioning correctly
Posted on Jun 05, 2009
SOURCE: Xerox fiery server
Fiery.1 usually does the trick
Posted on Jun 19, 2009
Xerox 240 fiery displays ff
May be try reinstall solfware. Sometime H/D will cause this problem too.
Apr 03, 2014 | Xerox DocuColor 242-252-260 PS
Fiery problem showing FF on display no tconecting to network
did you resolved the problem ? I'm getting the same one, thank you!
Mar 29, 2012 | Xerox DocuColor 242-252-260 PS
Hi I buy the xerox docucolour 12 printer please please i need to install my xp computer and vista computer how i install driver and configire if you have any video instraction file pls share me tks a...
hi friends,
this is aditya (+91)9836593201.
at 1st you go to front of your fiery & xerox machine,an on it.
when dc12 will show redy to copy and fiery show go to start butten on your xp os.
printer and fax >
add printer>
locale with automatic >
(sarching...) >
next >
creat a naw port->
standerd TCP/IP >
next >
type your fiery IP address on the box of printer name >
next> next> next>
have disk>
(select location of your printer driver)>
next> next> next>
your printer driver have to install.
May 21, 2011 | Xerox DocuColor 12 Printer
Hi Dear Can use xerox DC12 with MAC OS without
There are some Mac OS drivers.I think your printer is not compatible with Mac.
The level of functionality and compatibility with the new Mac OS X 10.6 drivers are identified in the following document.
> For a list of Xerox equipment compatible with Mac OS X 10.6, click here.
DocuColor 12 Copier/Printer
Dec 14, 2010 | Xerox DocuColor 12 Printer
Can you scan to file on the xerox docucolor 12 with the fiery x12 color server
yes it needs one printer cable and one scanner cable connected between fiery and machine
and scangear software install and remote compputer
Apr 23, 2010 | Xerox DocuColor 12 Color Copier
Xerox docucolor 3535 error 016-387
I've seen plenty of these issues with Fiery's connected to all manner of printers.
Actually, 016 errors are network related issues. The 387 usually indicate an issue with tthe switch device that the fiery is connected to and not the fiery itself. Get the connection from the fiery to the switch checked out and also the port status on the switch itself. Also recycle the Xerox and Fiery and you may also have to recycle the network switch as well.
Sep 14, 2009 | Office Equipment & Supplies
Fiery patches
hi better u try to
Oct 01, 2008 | Xerox DocuColor 12 Printer
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
