Question about Plumbing
Where do pipes go on my qulacast pc40 - Plumbing
Where can i get a users manual from for the pc40 chainsaw
Hi Michaela:
Chain saw manuals can be quite similar.
Here's a link to an excellent one that should give you most of the information that you need.
http://www.oregonproducts.com/pro/pdf/maintenance_manual/ms_manual.pdf
Cheerfuls.
Oct 19, 2015 | Garden
Todd PC30B schematic
http://www.electronicspoint.com/rv-power-converter-todd-pc40-insulator-problem-t46674.html
Aug 14, 2014 | Computers & Internet
Where ?
Hi this should be a good link:
http://www.einhelltools.co.uk/pdfs/store/728.pdf
First two/three pages are in german, then the Qualcast manual is below :-)
May 13, 2014 | Garden
Chain replacement on qualcast pc40 chainsaw
Follow the instruction in owners manual page 8 click link belowchain replacement
click here page 8
Nov 20, 2013 | Garden
Qualcast petrol chainsaw manual Pc40
where can i get a manual for my qualcast pc40 chainsaw
Jul 27, 2013 | Garden
Lost the slew on a kamatsu pc40
Check that the key in the drive gear is not sheared in half. check that by trying to slew and see if the drive motor is working. The hydraulic motor may be seized up
Mar 19, 2013 | Joal 1/32 Komatsu PC 450 LC-6 Excavator
Qulacast classic 35 s wont start unless i take plug out and put some fresh fuel in engine chamber then it starts up burns that fuel then cuts out, i have cleaned all carb out apart from the main jet as it...
the jets have 4 ports. did you clean them all out? If damaged real bad, replace it for one or more of the fuel ports can be smashed together starving the fuel flow to run
Jul 24, 2011 | Garden
POWERCRAFT PC40-38cc.THE CHAIN OILER DOES NOT APPEAR TO BE WORKING! NO OIL IS COMING OUT THE SMALL HOLE IN THE HOUSING THAT THE BAR IS CLAMPED AGAINST, WHEN I RUN THE ENGINE WITH NO BAR AND CHAIN...
It would appear that you must 'go under the cover'. Look for a damaged oil line or split oil tank. The oil pump may have come loose from it's mounting. Be sure to check the oil filter for plugging. Hope this helps!
Dec 21, 2010 | Garden
Plumbing Logo
49 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
