Question about Dell 1710n Laser Printer
Toner light flashing althougth I have changed the toner and was shaking it before I inserted it..
    Scholar:
  • 71 Answers
Toner should be carefully inserted into the Place where it resides.
Improper installation makes this light flashing.
Stpes to be done :
01. Remove the toner gently from the toner drive.
02. Shut down PC and the Dell Printer.
03. Re boot the machine and the Dell Printer.
04. Ensure Power and network cable is installed properly.
05. Use only genuine and Dell Authorized toners in the Printer. Clean the place with nice white cloth with cleaning liquid.
06. Now you can take a test print out.
07. Still the problem persists, please call Printer Service engineer to solve the issue.
Posted on Jul 21, 2009
How to reset the printer --appears to be no paper jam and appears to have toner but red light keeps flashing
the toner is not inserted properly and is not detected by the system .pls try to re insert the toner this time make sure that it is inserted properly and the motor winds it up then closer the cover and locks it.this will till the system that toner is loaded and is ready to print..
Jun 06, 2012 | Kyocera FS-920 Laser Printer
The toner light on , and no print
The toner probably needs replacement. You can try to remove the toner cartridge, shake it, and insert it again to continue printing.
Jul 19, 2010 | Brother HL-2040 Laser Printer
Replaced the waste toner box.
re check for the toner inserted, be sure that protected plastic remove. shake and insert again.
Apr 15, 2010 | Samsung CLP 315 Laser Printer
Changing black toner cartridge
To change your toner first turn off the printer and unplug it from the power outlet. Then, lift the toner door. Carefully grap the toner cartridge from both ends and lift it up. Do not shake the toner as you may get dirty. Then take the new toner cartridge, remove any plastic covers and insert it in the printer. Close the toner door and start your pritner.
Feb 08, 2010 | Xerox Phaser 6120/YN Laser Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
The drum light came on constant my Brother HL-1440. I changed the drum and also put new toner in, slid the cleaning button back and forth. But I still have the drum light on constantly and the print is...
Could be a defective drum, but do the reset first, Open the front door and hold the go button until the lights flash and it will be reset. after that just shake the toner and hope for the best...
Aug 10, 2009 | Brother HL 1440 Laser Printer
Said we need to have toner we just replaced the toner
Please remove the toner cartridge and shake it side to side. then make sure it's inserted all the way in.
May 19, 2009 | Canon NP 7130 Black and White Copier
No toner message
The control panel display will indicate which toner is out;
K = Black
M = Magenta
Y - Yellow
C = Cyan
Also, the orange indicator light will flash.
Generally, each toner will provide about 1,500 copies depending on the intensity of the specific color. The toner drums, on the other hand, generally provide more than 20,000 copies each and need not be changed that often.
When you change a toner, included with the toner is a little alcohol wipe that you use to clean the toner sensor. This is a small LED located along side the toner holder. Make sure ALL toner waste/dust is cleaned off the sensor before installing the new toner.
Also, while I hate to state the obvious, make sure you removed the tape from the new toner before inserting it. Last, make sure you lock the toner in place with the blue lever. And it never hurts to shake the toner a little side to side before inserting it just in case the toner has gathered at one end.
Last, there is a utility included with the printer that lets you access the printer's information via your computer. This will tell you exactly how much toner is left in each cartridge and the life remaining on the drum.
Feb 04, 2009 | OKI C3200n Led Printer
The drum light came on (Brother HL 5240) and I replaced the drum with a new one and it still will not work... Any suggestions?
I continued looking and found where someone else had the same problem. I opened the front cover, held down the go key for 10 seconds and closed the door. This reset something because it works now.
Thanks
Jan 20, 2009 | Brother HL-5240 Laser Printer
Flashing red light
On the alarm and data light blinking, it is saying the toner cartridge is empty. You will need to replace it. Once in a while you can remove the toner cartridge and shake it and have it work for a little while longer. This does not work all the time however.
If you can't get it to work by shaking it, you will need to purchase a new toner cartridge.
When you have the new cartridge, you will need to slide the blue corona wire cleaner back and forth. This is just in front of the toner cartridge in the drum unit on the top of the drum unit. There is a small light blue colored piece of plastic with an arrow in it that you will just push back and forth. This will help the drum unit do its job better.
May 06, 2008 | Brother HL 1440 Laser Printer
Dell 1710n Laser Printer Logo
176 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
