Question about Sanyo Televison & Video
How do I set up a Sanyo blu ray player without the startup disk
  • Sanyo Master
  • 10,101 Answers
Blu ray players use a Hidef cable set or an HDMI cable connected to your TV. Startup disk? Never heard of one.
Posted on Feb 04, 2017
Agent Jason
  • 78 Answers
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Go Ahead. Use Us.
Posted on Jul 23, 2008
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck
Posted on Mar 31, 2009
SOURCE: LG Blu-Ray BD-370 unlock codes
Posted on May 01, 2009
  • 36 Answers
SOURCE: Our Sony Blu-Ray BDP-S300 will play older Blu Ray
Try to update the firmware on the player by going to this website the newest version is 5.20 fixes alot of problems including playback issues with some BD movies and safe the file into a flash drive and plug it in on the back USB port, go to menu/firmware update run the update.
Posted on Jan 12, 2010
SOURCE: Salt blu ray will not
Update your FW to at least 100112.01.XSS
Posted on Jan 10, 2011
I have a Sanyo blu ray player it plays dvds but blu rays only play the previews when I push play their is a red circle with a line threw it
Blu-Ray DVDs have some serious security encryption on them to avoid piracy. This encryption is constantly going through evolution. It is up to the manufacturers of the players to provide updates to allow the older players to play the newer content. Check to see that your firmware is current. This is most likely your problem.
Nov 02, 2015 | Sanyo Televison & Video
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Feb 16, 2014 | Sanyo Televison & Video
Sanyo 500 tries to load dvd but won't play dvd
Does that specific DVD work in some other DVD player?
Does that specific DVD work in the DVD-drive in your computer?
Dirty disk?
Feb 15, 2014 | Sanyo DVW-5000 DVD Player/VCR
The tray is being operated or a disc is being read
Using flash USB drive to play video on Sony Blu Ray DVD player
"The tray is being operated or disc is being read. Cannot perform this operation"
you need to change the default settings on your Sony Blu Ray player.
navigate to
System Settings
Switch fast startup mode off
this will change the startup time back to "normal" from "fast"
This gives the Blu ray player more time to read your USB flash drive, esp. larger flash drives,
which need more time to register in the memory of the Sony's processor.
Dec 26, 2013 | Sony Bdps390 Bluray Player
Hi, I have a Samsung Blu-Ray BD-C5900 and I it does not play all regions DVD's, I would like to play all regions on m Blu-Ray, is there a code that can set this up?
Turn your BD on without cd in it, wait until appear no disk on screen.
Use this combination : Repeat-5-6-7-3-2-9
You should seen "9" on right of screen.
Good luck.
Apr 01, 2011 | Samsung BD-C5900 Blu-ray 3D Player
Hi Can you tell me how to upgrade the firmware on my bd370 without connecting it to the internet. I have down loaded updates from onto a CD-R but when i put it into the player, it should goto...
Hi there
If you download the updates onto a CD-r and insert it into your player it should automatically update itself but if it doesnt then you should try downloading the updates on a DVD-R disk
This should work
Oct 02, 2010 | LG BD370 BLU RAY PLAYER
Dvd player won't quit scrolling even without disk
cannot connect dvd-8150 to my sanyo hd ready tv by red white & yellow cables
Feb 01, 2010 | Televison & Video
SANYO (DVD) Recorder + vcr HVR-DX625H.
I think there should be options that allow you to protect the disc or not. Check your settings.
Oct 31, 2008 | Sanyo DVW-6000 DVD Player/VCR
Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
Jun 03, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Televison & Video Logo
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
