Question about Garden
How to set spring on idler pully on snow blower
  • 2984 Answers
SOURCE: 1996 Cadillac Seville idler Pully Belt will not tighten
Your belt may be the wrong length. It is too long. Where did you get it from?
Posted on Mar 14, 2009
SOURCE: idler pully set bolt,standard or reverse thread?
standerd left loose
Posted on Jun 01, 2009
  • 1304 Answers
SOURCE: how dose belly go on around idler pully
pull the loop togehter from the bottom of the drum
feed the loop threough and under the pully wheel
clip the loop on the motor pully
Posted on Oct 18, 2009
  • 59 Answers
SOURCE: i need an idler pully
go to
Posted on Sep 23, 2010
  • 2050 Answers
SOURCE: I have a 1997 Jimmy. I smelled rubber burning,
Just an idler, probably has a frozen bearing, you will need to get it repaired.
Posted on Jun 18, 2011
Replaced a broken auger control cable on my 536.881400 snow thrower, but now the auger engage lever cannot be fully pulled back.
possible that is the problem
see if you can move the end of the cable closer down the handle (control lever) to give it enough length
check how you fitted the cable and the spring may fit in a hole on the other side of where you put the cable end
Nov 29, 2016 | Garden
I have a Cub cadet my 1018 with a 42 inch deck my iderlerspringcameoffneedtoknowbothbothplaceoneachendtoreconnect
Go to your local cub dealer with the modle number of the deck. They have diagrams that will show how to connect the spring correctly. If the spring came off it may have lost tension or part of the hooks on the end of the spring broke off. I would get a new spring. I have also seen the the idler pully get sloppy and not keep the idler pully properly lined up with the other pulleys.The belt will then ride up off the pulley and the spring will come off.
Sep 28, 2014 | Garden
C950-52118-2 Belts
there should be like a idler pully which is held on by a spring and pully look on youtube most are the same setup
Jan 05, 2014 | Craftsman Snow Blower / Snowblower Bottom...
I have a 30" husqvarna snow blower. 1 year old. The auger belt is really loose and keeos slipping off the main pully and smoking like crazy. I replaced with a new belt and still had the same problem. Any...
Page 17, figure 23 of the manual shows a "Clutching Idler Arm Bracket" that should take up slack. Does it have a broken spring, or is it seized because of ice or rust? The very top of the page does mention that the belts aren't adjustable, but why else is the idler arm there if not as a tensioner?
Dec 14, 2013 | Husqvarna 1830EXL 30" 414cc Crown Series...
Drive belt on deck keeps jumping off
The belt tentioner is loose.
Jun 22, 2013 | Craftsman Garden
How do i change the drive spring on my craftsman 4/21 snowblower
Is that the spring under the plastic hood behind the snow throwing shoot?
Dec 10, 2012 | Craftsman Snow Blower / Snowblower Bottom...
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
How to adjust the Toro 826 snow thrower
Belts will have spring tension on the idler pulleys.
Both traction and auger control cables will also have cable length adjustments to cause the travel of levers or idler pulleys to tighten belts. Adjustments are commonly located under the control panel/levers.
Dec 03, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
