Question about Garden
I changed filter and oil in my 1863 cubcadet hydrostatic now it dosent move
    New Friend:
  • 40 Answers
Be sure you used the correct fluid. If it is not the right will not engage properly.
Posted on Dec 28, 2016
My 50" club cadet just stopped moving foreword or backward while I was mowing. Do you think it's the transmission?
its more than likly a bad check valve or a by pass is clogged make sure change oil a filter in hydrostat after fix best while they are fixing it to fi9x check valve 100.00 to put new bypass 50.00 to change oil 100.00, 250.00 to be safe
Sep 03, 2014 | Garden
Kubota troubleshooting
chang filter and hydrostatic oil
Aug 27, 2014 | Garden
Where is the filter on a 80-84 wheelhorse hydrostatic trans. And does it take motor or hydrolic oil ?
im unaware of any external filter on this tractor allways use hydraulic oil in hydrostatic transmissions cus it's usually synethic so it can take the heat as to your problem id be suprized if an oil change would fix that ( not if you been puttin motor oil in there) i suspect a activator valve is worn inside and this produces the simptom you describe Lot of hours on transaxle ??
May 20, 2014 | Garden
What is the bypass on the transmission for cubcadet 1554
its and oil bypass incase oiul filter is clogged chang oil filter or youy will burn out tans
May 13, 2014 | Cub Cadet Lawn Mower Hydro Filter Replaces...
What's your problem?il oil light stays on
there is a oil pressure switch on the oil filter hosing did you knock the wire off when changing the filter?
May 29, 2012 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
I have a john deere 316, the other day i was moving snow with it and all of the sudden it lost all power to the hydrostatic and to the front end quick attach. I was wonder what would cause this and how to...
First check level of hydraulic oil. Sight plastic tube just above and to the right of the hitch. Should be in the middle of the tube.
How long since you changed the hydrostatic oil filter under the seat deck?
Next see if the small splined shaft is turning btween the seat deck and the transaxle from the rear of the tractor. If not, it sheered a key in the hydrostatic drive shaft from the motor to the drive. (Had this happen to me)
Check the lever under the right side fender that disables the hydrostatic transmission to allow the tractor to to be moved without dragging the wheels. Make sure its not in the wrong position.
If all these are ok then the hydrostatic pump has failed.
Jan 01, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
Jul 18, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Looking for when the oil and transmission should be changed on Lt
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Sep 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
What kind of oil do I use in a Wheel Horse lawn tractor?
Your Onan engine will do excellent with Mobil One 0w40, Mobile One 5w30.
DO NOT use hydraulic oil in the transmission/transaxle, you will destroy it. Your tractor uses an Eaton 11 Hydrostatic transmission pump with the oil resevour being the cast iron transaxle. The WheelHorse transaxle is as rugged as they come. It uses a solid cast iron housing, case hardened intermediate gears and forged differential gears with an eight pinion differential.
Your transaxle requires 10w40 synthetic or conventional oil as well as a wix 51410 filter or the OEM wheelHorse filter. It should be changed every 100 hours with conventional oil or 250 hours with synthetic. DO NOT use hydraulic oil!
Jun 24, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
