Heater blower comes on for app 10 seconds then shuts off and E1 signal comes on, pressure gauge shows zero, put new air filter, cleaned fuel line but still no pressure on gauge
4 Suggested Answers
  • 583 Answers
SOURCE: Reddy heater shuts off when shell is put on
check out the fuses getting blown out on the internal chip circuit board and also the overheating component on that same circuit boasd.the burnt component will look little bit extra blackish on its sides.
Posted on Mar 03, 2009
  • 674 Answers
SOURCE: Have dyna glo forced air
Are the hoses on the fuel nozzle right. Air hose to the front and fuel to the rear. Did you remove the nozzle from the adaptor to check the o-ring? Let me know what you find.
nitensheaterservice@earthlink.net
Niten's Heater Service on Facebook
Posted on Jan 14, 2011
heatman101
  • 43501 Answers
SOURCE: dynaglo forced air kerosene heater fuel not
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Jan 28, 2011
Help I have a 2003 Kia sedonna that is fuel injected. I ran the car out of fuel. put in a new fuel pump bled the lines and got the car started. It ran for over 30 minutes has 1/2 tank of fuel. After I shut...
Fuel Pressure at motor with a gauge
No bleeding to do
Once the pump comes on you have fuel pressure
Once the computer sees a crank sensor signal the injectors
pulse & all air is blown out into the cylinders
Mar 27, 2013 | Kia Sedona Cars & Trucks
Have dyna glo forced air kerosene heater, 65000 btu. It's about 10 years old. Not getting fuel to nozzle. Cleaned fuel filter; replaced hoses; cleaned nozzle. air pressure gauge shows pressure OK.
Jan 13, 2011 | Dyna-Glo Heating & Cooling
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
I have a reddy heater model 170T ...Every time it starts and runs for 3 mins (app. ) Then shuts off . First the control panel, red lights , says it is a voltage problem ...now it says it is a fuel problem...
DESA bought out the assets of Reddyheater when they went bankrupt, I'd check with them for the manual. Torpedos are pretty bullet proof provided they are maintained.
A shut down at 3 minutes tells me its operating out of spec for one reason or another.
First thing is make sure your fuel is good... drain it all out, check for or crud in it, as such will raise havoc.If its clean, put it back in, if its contaminated, then get new fuel... don't run the old stuff down the drain.
Next, check the fuel filter and external air filter and if they are dirty replace them.
At this point, you need to put a gauge on the pressure port, your manual will have specs on this, and this is a mission critical adjustment. If its off, you will run too lean or too rich, and your machine will shut down in 3 minutes.If you can't get it set, it could be an air of fuel leak, or it could be a dirty inner air filter, or it could be fracture vanes at the pump. You can get a old style fuel pressure gauge from harbor freight for a few bucks to do this...
Oct 18, 2017 | Heating & Cooling
Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Mar 09, 2009 | Reddy Heater 60,000 BTU Kerosene...
Bought a reddy heater 155,000 kerosene.It wont draw feul.Hoses are clear (translucent) and also are not plugged. I can blow thru both & hear air come out the oriface. Am try to find out if previous owner...
the fuel line goes to the back of nozzle and the air line goes to the front.the air line and fuel line are not clear on that unit.sounds like some one changed them.also the fuel filter goes in the unit backwards from what the arrow shows.check your air pressure.you need to put a gauge on it so it is correct.
Feb 23, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
70,000 BTU Ready Heater
If...the air pump pressure is right, the ignitor glows, the fuel is hitting the ignitor, then the unit will have combustion......unless.....
  1. there is an air leak on the pressure line
  2. there is a vacuum leak on the fuel line
  3. there is a leak at the nozzle adapter
  4. there is a restriction either in the nozzle or the fuel filter
  5. the nozzle is worn and is spraying fuel rather than fogging fuel
Feb 09, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
NO FUEL AT NOZZLE
FOUND THAT THE FUEL HOSE AND AIR PUMP HOSE HAD BEEN REVERSED AT THE NOZZLE-PUMP HOSE NEEDS TO BE CLOSEST TO THE BLOWER HOUSING-I USED A VAC GAUGE TO TEST THE FUEL LINE-WHILE THE AIR PUMP WAS RUNNING-NO VAC-REVERSED LINES AND STARTED UNIT-ADJUSTED AIR PRESSURE-ALL IS WELL
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater RM60 HSI Forced Air Heater: Pump Pressure Issue!!
ground wire on the circuit board needs to be checked and these units need to have a GOOD three wire cord with a proper grounded outlet
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
Heater starts up but quits after 20 seconds?
what is the air pressure set at.very important it is set exactly or the unit will not work properly.need to have a pressure gauge to set the pressure....
Jan 13, 2009 | Dayton E51 Oil Filled Utility Heater
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
