Question about Logitech Audio Players & Recorders
Where can I get a new on off volume pot for a Logitech speaker system
SOURCE: Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
Posted on Nov 23, 2008
SOURCE: adjusting the subwoofer volume seperately from speaker volume
You can't exactly set volume but definitely turn down the bass which lowers the sub's output. Thats all we can do i think.
Posted on Aug 17, 2009
SOURCE: Logitech Z-340. I need access to the volume pot in
You need to pop off the grille on the front of the speaker. It's glued to the front. I just used a flat head screwdriver and worked it evenly around to slowly slide it off. Then, unscrew the 4 phillips screws to get to the inside.
Posted on Sep 06, 2010
Testimonial: "Haven't tried it yet, but it looks like good advice. Thanks"
bronk50
  • 27725 Answers
SOURCE: New laptop. Hooked up Logitech
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Posted on Feb 19, 2011
savers2008
  • 286 Answers
SOURCE: The volume nob on my
Dont get a new speaker, you cant get a new nob for it. Try Tandy, radio shack or Maplins. You can get one from them. Hope this helps
Posted on Apr 07, 2011
Logitech Z-340. I need access to the volume pot in order to clean it. How can I take right speaker apart?
Sep 03, 2010 | Logitech Z-340 Computer Speakers
I have this set, and one of the speakers do not already function? can anyone tell me how to fix it...pls...
It may be the same problem as mine, a dirty volume control. It can be cleaned with contact cleaner, available from radio shack, or any electronics store. You need to pry the front grill off carefully with a flat screw driver, remove 4 screws to gain access to volume pot. Do both speakers work at some volumes?
Mar 07, 2010 | Logitech Z-340 Computer Speakers
I have the logitech z-2300 just the other day the
mine did the same thing today , i just bought these new 2 weeks ago . the black prong speaker works in both ports ..
the yellow prong speaker is the one with the malfunction .
it works sometimes but when i turn up the volume louder it dies out .
Feb 23, 2010 | Logitech Z-2300 2.1 Computer Speaker...
My dog ate the cord for the volume control. How can I buy a new one?
type in Logitech Z-2300 speakers volume cord that may help or check from where you bought them
Jan 29, 2010 | Logitech Z-2300 Computer Speakers
Adjusting the subwoofer volume seperately from speaker volume
Mar 12, 2009 | Logitech Z Cinema 2.1 2.1 Speakers
May 15, 2008 | Logitech X-530 Computer Speakers
Feedback sound, hissing , in speakers logitech X-540
You may want to try disabling/muting the microphone volume in the volume control. If it doesn't help please post back.
Feb 19, 2008 | Logitech X-540 Computer Speakers
Sub Woofer Not Working
Make sure it is plugged in and the volume is up. Also make sure you don't have your sound muted. Do any sounds come out of your computer? Go to the control panel and click sounds and do a test.
Dec 25, 2007 | Logitech Z-2300 Computer Speakers
Volume control on the master speaker
If its a rotory type control simply take the rest out or off the pcb if you can and on the side of almost any varable resistor or pot is a value. Look to see if radio shack has that value or check your local electronic parts supply house and solder back into place But you may not get the exact one as they all have differant mechanical standards as the shaft may be too long or it may not fit on the pcb so you will have to drill into the cabinet and mount where theres nothing in the way and hook the wires to the control from where the old control was. Hope this helps good luck
Mar 11, 2006 | Logitech X-530 5.1 Channel Speaker System...
46 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
