Question about Apple iPad Tablets & eReaders
I have got a email account trying to get onto it using my iPad I did tap on my photo
Old emails
Go to Settings>Mail, Contacts, Calendars. Under the Mail window - go to Show> and select the number of recent emails that you want the iPad to load in your email accounts.
While you are in the mail settings - tap on the email account, tap on the account in the next window, tap on Advanced in the next window and tap Delete - and select the amount of time that you want the emails to stay on the iPad.
In some mail accounts there will also be an option for Delete from Server - tap that and set it to never if you want to control when to delete your old emails.
Go back to your email inbox in the mail app and swipe down to the bottom of the window - there may be an option to "load more messages from the server" in blue letters. Tap that and you will download as many odl emails as you set up for in the Show recent messages setting. At the top of the inbox is a search field - type in keywords in that search field to find old emails.
You can also search for emails in the spotlight search. Go to the home screen and tap the home button and the search feature pops up. Type keywords in the search field at the top to find old emails there as well. When you tap on that email in the search, the mail app will open and you can read the email.
Jul 21, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How to send a photo
The easiest way to send pictures from your iOS device (iPad, iPhone, iPod Touch) is to start by going into the Photo or Video App, selecting the photo or video you want to share and tapping the send icon at the left bottom corner under the photo.
Next, a menu will pop up asking you how you wish to send it. Depending on the device, the options may be slightly different, but Email Photo should be available for all iDevices. Tap Email photo.
send-photo-vieyp0ksuxq3crfthi5r4xws-3-0.jpg send-photo-vieyp0ksuxq3crfthi5r4xws-3-2.jpg send-photo-vieyp0ksuxq3crfthi5r4xws-3-5.jpg How To Send Pictures Videos from iPad iOS
Mar 04, 2014 | Apple iPad Tablets & eReaders
On my ipad I can not send pictures though email.How can I mix my promble
In the mail setting (setting icon), you should set the default account that is used by applications other than mail, like the photo application.
Nov 20, 2013 | Apple iPad Tablets & eReaders
Writing an email on my ipad2, need to attach pictures which are also on the iPad. How do I do this?
The easiest way to do this is to add the photo first and then text. To email a photo, tap the photos icon, view the photo you want to email and tap the share icon. An option to email should pop up.
Tap the email option and the photo will be inserted into an email. Then you can add any text needed within the same email.
Hope that helps!
Aug 31, 2012 | Apple iPad 32 GB 3G Tablet PC
Can not get my emails on ipad, on computer its ok, but now they will not sinc together
Try removing email address then installing again with new password.Tap settings,tap mail,contacts,calendars.Tap account,then delete account.Then go to mail again,tap add account to enter new with new settings.
Please Rate.
Aug 19, 2012 | Apple iPad 64 GB WiFi
How do I Sync Outlook from my Desktop Computer to my Apple IPAD?
To sync e-mails to your iPad, you must put the e-mail account details directly into the mail app. This is because Outlook is merely an application to download and read e-mails.
To add an e-mail account to your iPad:
1. Tap the Mail icon at the bottom of the home screen on iPad.
Step 2. Then tap to add type of email account that you want at add among: Microsoft Exchange, Mobile me, Gmail, Yahoo Mail, AOL or others. For example, if you want to add a Yahoo mail, just tap the Yahoo mail as follows:
Step 3. Then enter login details for selected email account type.
It will configure automatically and you should able to send - receive emails.
Aug 12, 2011 | Apple iPad 32 GB WiFi Tablet PC
Good day, i can't see my emails in my email inbox on my ipad any suggestions.. tnx
To check for account tap settings and tap mail,contacts.calendars.Under accounts see if any listed.If account is not listed tap add account and choose service then sign in.If listed choose account and check settings for correct address and password.Click done when finished
Jul 13, 2011 | Apple iPad 32 GB WiFi Tablet PC
What is the easiest way to import MS Outlook (addresses, telephones, mail etc) from my laptop to my new ipad
Connect your ipad to an exchange server. You can do it by following these instructions:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
Your username is the one you use to access mail at work.it could be firstname and initial like (robd) for example or it could be your email address. Next, the server field you put in the server to connect to. Every business has a different name for this field. You should ask your IT dept. if you are unclear what your account credentials are to fill in these fields.
But once you are connected to the server, you can specify what you want to sync onto your ipad. Contacts will be found in the address book under "Groups" these contacts will than pull from your exchange connection.
Hope some of this helps.
Feb 11, 2011 | Apple iPad 64 GB 3G Tablet PC
Can't set up mobile data plan for new 3G iPad
Follow these steps to set up your new Cellular Data account :
1. Tap Settings > Cellular Data > View Account:
2. The Cellular Data Account management window loads. Enter information or select an option in the following sections and tap Next when you are finished:
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--cellular_data_account-004-en.png
User Information Enter your first and last name and your phone number.
Login Information Enter an email address and a password. This creates an AT&T account, allowing you to log in to the account later to make changes or view your usage statistics.
Recurring Domestic Plan Options This allows you to choose the type of plan you want to use.
Payment & Billing Information Complete this section with the billing information you’d like to use to pay for your Cellular Data account.
You can tap "Use a different service address" if you're billing address is a P.O. Box or Rural Route, and enter an alternate address for your service address
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--cellular_data_account_service_address-001-en.png
Note: You cannot use a P.O. Box or Rural Route for the service address. AT&T requires that you use a street address for the service address. Please see this Document from AT&T for more information.
3. The Terms of Service agreement loads. Take a minute to read this agreement. Tap Agree to continue.
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--terms-002-en.png
4. The Payment Summary loads. This shows you a summary of the account and plan you have selected:
ht4157--payment_summary-003-en.png Note: You can also add an International data plan on this screen by tapping Add International Data, or you can access your account later to manage your plan options. If you need to use your iPad internationally, you must sign up for the international data plan while in the United States.
5. Tap Submit to complete the creation of your Cellular Data account. The Congratulations screen loads. This lets you know that your account has been created, and that AT&T is activating your iPad. Tap OK to finish and return to the Settings screen of your iPad Wi-Fi + 3G.
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--congrats-002-en.png
Your iPad will notify you when your Cellular Data connection has been activated :
http://km.support.apple.com/library/APPLE/SECRET_PRODUCTS/S_PROJECT_15/HT4157/HT4157--data_plan_activated-001-en.png
While waiting for this activation, you can use your iPad Wi-Fi + 3G on Wi-Fi.
Additional Information Note: The Cellular Data account sign-up process is managed by AT&T. If you have questions, concerns, or problems with this sign-up process, please contact AT&T.
If you need to change or correct your email account information, please contact AT&T.
Note: A unique email address is required for your AT&T account. If you plan on setting up cellular data accounts for multiple iPads, you must use a different email address for each account.
Apr 30, 2010 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
27 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
