Word using letter i o o i w d h - Computers & Internet
Make two words with the letters oorreethbigt
reboot & tiger (letter not used -h)
borer & hogtie ( letter not used -t)
bigot & there (letters not used - o&r)
May 25, 2016 | Computers & Internet
What words can i make using these letters im stuck and have been at it for days i an trying to use as much letters i can m-d-u-c-r-o-a
Check out this Web site for help finding words made from the letters you listed:
http://www.wineverygame.com/wbg.php?letters=MDUCROA&lettersh=MDUCROA&preffix=&preffixh=&oa=or&suffix=&suffixh=&submit=Find+Words&pr=
Nov 05, 2015 | Miscellaneous
Unscramble two words - oreefmilcc _____ ______
Since you only gave ten letters, it's impossible to make a five-letter word and a six-letter word from them without using a letter twice.
May 25, 2014 | Computers & Internet
How many 8 letters arrangement are possible using the letters of the word DECAGON if the letters A,E and O must occupy the third, fifth and sixth positions respectively and the letters remaining may be...
xxAxEOxx where x can be any of the letters in the set {d,c,g,n}.
There are 4 choices for the first x. Once the first x letter is chosen there are 4 choices for the second x, etc. Since you have five x positions to fill , the number of arrangements is 4^5=1024 (product of number of choices in each step). I used the multiplicative principle.
So you have 1024 possible 8 letter arrangements satisfying your conditions. Most of those arrangements are no doubt meaningless in English.
Sep 20, 2013 | Office Equipment & Supplies
The file on my Seagate FreeAgent Pro 880 gig , wont restore to new formated drive ............ letter have change when reinstaling Windows Xp. I see all the different partition on the Seagate. But the...
The Disk Management snap-in is an administrative tool for managing hard disks and the volumes or partitions that they contain. Use the Disk Management snap-in when you want to add, to change, or to remove drive letters on drives, on partitions, or on volumes on your computer's hard disks, CD-ROM drives, and other removable media devices.
Your computer can use up to 26 drive letters, from A through Z. Use drive letters C through Z for hard disk drives. Drive letters A and B are reserved for floppy disk drives. However, if your computer does not have a floppy disk drive, you can assign these letters to removable drives.
Before you modify drive-letter assignments, note the following items:
  • Changing the drive letter of the system volume or the boot volume is not a built-in feature of the Disk Management snap-in.
  • Many MS-DOS-based and Microsoft Windows-based programs refer to specific drive letters for environmental or other variables. If you modify the drive letter, these programs may not function correctly.
How to assign a drive letterTo assign a drive letter to a drive, a partition, or a volume, follow these steps:
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
    Note If you do not see Performance and Maintenance, go to step 3. Performance and Maintenance appears in Control Panel only if you use Category view. If you use Classic view, Performance and Maintenance does not appear.
  3. Click Administrative Tools, double-click Computer Management, and then clickDisk Management in the left pane.
  4. Right-click the drive, the partition, the logical drive, or the volume that you want to assign a drive letter to, and then click Change Drive Letter and Paths.
  5. Click Add.
  6. Click Assign the following drive letter if it is not already selected, and then either accept the default drive letter or click the drive letter that you want to use.
  7. Click OK.
The drive letter is assigned to the drive, to the partition, or to the volume that you specified, and then that drive letter appears in the appropriate drive, partition, or volume in the Disk Management tool. Thanks or using FixYa! John
Feb 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Device doesn't work. maybe it needs new drivers
The following is from Windows Help, which I found by looking up drive letter:
  1. Open shortcutcold.gifComputer Management (Local).
  1. In the console tree, click Disk Management.
  2. pluscold.gifWhere?
  1. Computer Management (Local)
  • Storage
  • Disk Management
  1. Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths.
  1. Do one of the following:
  2. To assign a drive letter, click Add, click the drive letter you want to use, and then click OK.
  • To modify a drive letter, click it, click Change, click the drive letter you want to use, and then click OK.
  • To remove a drive letter, click it, and then click Remove.
important.gif Important
  • Be careful when making drive-letter assignments because many MS-DOS and Windows programs make references to a specific drive letter. For example, the path environment variable shows specific drive letters in conjunction with program names.
Jan 31, 2011 | Buffalo Technology (HD-HB250U2) 250 GB...
Seven letter words in english with third letter d and fifth letter p the clues are politation like this, advocate use this , public hate this
seven letter words in english with third letter d and fifth letter p
the clues are
advocate use this ,
public hate this
Sep 20, 2010 | Puzzle Massey Ferguson Tractor
SimpleTech 320 GB hard drive not recognized by PC
Windows likes to play with drive letter assignments, especially when you remove a device without using the "safely remove hardware" icon. When you plug it back in, Windows may think that you've plugged in a new one and assign it a new drive letter. Try this:
uparrow.gifBack to the top How to assign a drive letter loadTOCNode(2, 'summary'); To assign a drive letter to a drive, a partition, or a volume, follow these steps:
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  5. Click Add.
  7. Click OK.
I hope this does it for you. Thanks for using Fixya!
Dec 11, 2008 | SimpleTech SimpleDrive 160 GB External USB...
Kds laptop
Follow the following instructions for XP:
Top open computer management, right click on My Computer and click on Manage.
To assign, change, or remove a drive letter
minuscold.gifUsing the Windows interface
  2. In the console tree, click Disk Management.
    pluscold.gifWhere?
    • Computer Management (Local)
    • Storage
    • Disk Management
  3. Right-click a partition, logical drive, or volume, and then click Change Drive Letter and Paths.
  4. Do one of the following:
    • To assign a drive letter, click Add, click the drive letter you want to use, and then click OK.
Oct 11, 2007 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
