Question about Home
Flames will not come on. Changed batteries in remote
I changed the batteries in my rca remote and now the indicator light will not turn off and the remote does not work
The new batteries may have been installed incorrectly. Check the polarity marking inside the battery compartment.
Nov 11, 2013 | RCA New Original CRK76WB3 Remote Control
Flames coming out of top and going into flue pipe
Did you change the orifice and regulator from Natural Gas to LP Gas? IF not, that's the problem.
Dec 27, 2012 | Heating & Cooling
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
Console not responding. have changed remote and sensor bar
This information comes directly from Nintendo's website. Hope this can be of help:
First, follow these guidelines to ensure you have set up the system properly to have the optimal environment in which to use the Wii Remote:
  • Check to make sure the Sensor Bar cord is inserted into the back of the Wii console and the Sensor Bar is centered above or below your TV screen (more info).
  • Make sure you are using fresh batteries in the Wii Remote.
  • The Wii Remote Controller should be used between 3 to 10 feet from the TV.
  • Make sure no objects are blocking the signals between the Sensor Bar, the Wii console, and the Wii Remote.
  • Check for interference from infra-red light sources, such as candles, sunlight, fireplaces, and stoves.
  • Radio frequency interference may cause the Wii Remote to work erratically. Check for wireless devices such as cordless phones, wireless computer keyboards or mice, or other similar devices, and move or turn them off.
Verify Sensitivity Setting dots:
Go to the Sensor Bar's sensitivity setting in the Wii menu.
  • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
  • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
Jan 02, 2011 | Nintendo Wii Console
Remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Dec 13, 2008 | Dimplex DS5603 Heater
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
