Question about Dryers
The drier functions o k but no heat - Dryers
    Top Expert:
  • Dryers Master
  • 44,045 Answers
Heating element failure
Posted on Dec 29, 2016
Top of GE drier hot
When the dryer gets toward end of cycle, the timer will cycle off the heating element. (last 5 - 7 minutes.) This function takes place thru a resistor located near the timer switch, and parallel with the heating element. If this resistor fails, the heating element stays on during the cool down period. The resistor can be checked with a meter. If it doesn't ohm out at 4500 ohms, replace the resistor... Make sure power is off at the appliance when you check for resistance.
Jun 23, 2014 | GE DBXR463EDWW Electric Dryer
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
Drier won't heat
try replacing hearter wire under drier
Apr 08, 2012 | Whirlpool Dryers
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
No heat
make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Apr 23, 2009 | GE Profile Prodigy DPSR513GA Dryer
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Roper Drier no heat and continuous run for two hours
Your drier heating elements operates on 220 voltage, the drum and clock operate on 110, so you either have a blown fuse in one side of the fuse box ( easy fix )some time the circuit breaker will just need to be reset by turning it off and back on, or your heating elemant has opened up and will be more expences to fix, or it could just be a wire end has burned off. unplug plug from outlet remove back from drier and have a look see, and if bychance you have forgotten to clean your link trap if could be a high temp safety that has open and sometimes can be reset by pushing the reset button, all this is inside the back of the drier, if after that it may be time to call your friendly repair shop
Oct 20, 2008 | Roper REX4634KQ Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
