Question about Dyson Vacuums
Dyson DC59 has stopped working after 2 years service. Picked it from docking station and nothing happened when pressed trigger, just got blue flashing LEDs. Put back overnight but same thing today.
When on docking station get flashing LED for about 1 minute then LEDs go out.
SOURCE: Roller/sweeper on my Electrolux Pronto
After 3 years my Pronto slowed down and needed new batteries. I just replaced all 8 internal batteries. It cost just under $30 with shipping and took 1 hour of soldering. If you're not handy with a soldering iron, don't attempt it. All of the batteries are soldered together in series. You need to order the 8 (4/5 Sc size, 2000 mAh) Nickel metal hydride (Ni-MH) batteries with tabs. The source I used was www.BatteryJunction.com. Here's a link to the battery page: http://www.batteryjunction.com/tenergy-45th-sc-1-2-2000-tabs.html
PS The vac now runs GREAT!
Russ
Posted on Jul 18, 2009
  • 4088 Answers
SOURCE: backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Posted on Jul 23, 2009
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
promo7uk
  • 19 Answers
SOURCE: I got a Dyson DC16 handheld cordless.
i have posted a fix on here ,,, its the magnetic transistor sensor on the pcb,,, common fault found the fix today...remove it and solder 1 wire from a+c on my diagram,,its at the top of long board that sticks up into a cavity off the main pcb..behind the serial number,,
remove it and solder a wire...like this
A
B C
SOLDER WIRE TO A + C AFTER REMOVING THE TRANSISTOR.. RIGHT AT THE TOP GUYS OF THE PCB... FIXS IT 99% OF THE TIME PROVIDING U KEEP IT CLEAN,
LET ME KNOW ALL WHO FIX ...CHEERS SAY THANKS,
Posted on Jun 24, 2010
jspahn
  • 103 Answers
SOURCE: I have the Dyson animal
You might want to check and see if your cyclones are plugged with hair. this can happen and there is a great site to disassemble and clean the cyclone here: http://www.exonotes.com/content/node/4
Posted on Aug 10, 2010
Inherited from family member who moved away, can't see how the charging cord fits into docking station as it doesn't line up with hole on vacuum body when inserted into docking station.
Hi there, it's Jack at Dyson.
All DC59 models were supplied with the docking station design shown below, which sounds as if it's the one you've seen in videos online:
From your description, it sounds like the docking station you've inherited may belong to an older Dyson cordless vacuum, such as DC35 or DC44. If you're able to call the Dyson Customer Helpline directly, we should be able to help determine exactly which docking station you have, and whether or not it's compatible with your DC59.
You can reach our experts by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
May 07, 2016 | Dyson DC59 Animal Cordless Vacuum Cleaner
Why isn't it charging?
I'm sorry to hear your DC59 doesn't seem to be charging. If you're recharging your machine in the docking station, make sure the end of the charger cord is correctly and firmly inserted into position. If the charger cord is not correctly installed, it may not be making effective contact with the machine. In normal use, DC59 should recharge from depleted within 3.5 hours.
If you're plugging the charger cord directly into the machine and have continued to experience this issue, please get in touch with the Dyson Customer Helpline directly when you have your machine to hand. Our experts will be happy to talk you through some simple diagnostic checks - and if a replacement part is needed, they can confirm if this is covered under your Dyson warranty.
You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 21, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How to fit wall bracket
When installing DC59's docking station, use appropriate hardware/fixings for your wall type and ensure that the dock is mounted securely. Ensure no pipe work (gas, water, air) or electrical cables, wires or duct work are located directly behind the drilling area. The dock must be mounted in accordance with all local laws and regulations and applicable codes and standards. Dyson recommends the use of protective clothing, eye ware and materials as necessary.
The charger cord assembly attaches to the docking station as shown below:
I hope this information helps. If you need any further guidance, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 04, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
I have had my dyson dc59 for about 3 months. Wheni try to turn it on by the trigger it won't start. I know it has a full charge so with my messing around with it i pressed the max button and it turned...
Hi Jeff, it's Jack at Dyson.
The issue you're describing with your DC59 sounds very unusual, but I'm sure we can help. Like all Dyson cordless and handheld vacuums, DC59 is backed with our 2-year Dyson parts and labour guarantee.
When you have your machine fully charged and easily to hand, please give us a call so we can talk you through some simple diagnostic checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 23, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
Insert charger lead in docking station
This diagram should help you attach DC59 Motorhead's charger cord to the docking station correctly:
However if you'd like some additional guidance on this from our experts, you're welcome to contact us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Oct 07, 2014 | Dyson DC59 Motorhead Bagless Cordless...
When I try to use my Dyson DC59 it won't start and blue lights on both sides of the battery start blinking. What does this mean?
From what you've described, it sounds as if you may be using your DC59 set to Boost mode. This will provide 6 minutes of highest suction for really stubborn dirt, but for regular vacuuming normal mode should work effectively.
To switch back to normal mode, ensure your machine is fully charged (this will take a maximum of 3.5 hours), then hold down the on/off trigger, and at the same time, press the illuminated Boost button on the rear of the machine.
You might also find our Getting started guide useful:
I'm confident this will resolve the issue, but if you would like some further advice from our experts after giving this a try, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 13, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
My dc59 doesnt work green light flashes when you press start button
A green light flashing when you try to use your DC59 could mean the battery has no power. If you're confident it's been allowed to charge for at least 3.5 hours, it's possible that the charger cord isn't connecting correctly with the machine itself, so no power is reaching the battery. This is more likely to occur if you're recharging the machine in the docking station, and the charger cord isn't correctly positioned.
We're happy to help you check for and resolve this - if a replacement part is needed we can also confirm if this is covered under our 2-year parts and labour guarantee. When you have your machine to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 27, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
WHY IS RED LIGHT FASHING on my DC59 cordless vacuum cleaner? I cleaned it and now it wont work.
Sounds like a faulty charger
Contact Dyson they have fantastic customer service and are cheaper then most repair companies
Aug 08, 2014 | Dyson Dc50 Ball Multi-Floor 2-Tier...
Why has my dc59 stopped charging
Hi David, it's Jack at Dyson.
I'm sorry to hear your DC59 seems to have stopped charging. It shouldn't have any issues with this when connected either directly with the charger cord, or when placed in the docking station as shown in our Getting started guide.
If you've checked to make sure there is no issue with the wall socket you're charging the machine from, and you're confident the charger cord is plugging securely into the machine as normal, we'd need to run you though a few further diagnostic checks when you have your machine to hand. This will help us determine what's causing the issue. If a replacement part is needed, we can also confirm if this is covered under the 2-year Dyson cordless guarantee.
Please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US) or 1800 239 766 (AU).
Jul 08, 2014 | Dyson Vacuums
My DC59 suddenly stopped working and won't turn on when I press the trigger
Push the reset and follow the manual info
the manual link is attached below
http://www.manual-hub.com/manuals/dyson-dc59-01-pdf-manual.html
Apr 30, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
Vacuums Logo
26 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
