Question about Dryers
Clothes dryer Logic LVD6W13 has stopped working any known problems?
  • Dryers Master
  • 8,220 Answers
Maybe child lock is on? manual: https://www.manualslib.com/manual/1086624/Logik-Lvd6w13.html?page=20#manual
Posted on Jan 04, 2017
Dryer is not turning off and not drying the clothes how to fix
Call a service engineer. you have a logic board problem, and an element problem, possibly high limit thermostat problems.
Feb 08, 2017 | Dryers
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryer worked earlier today. A drying cycle stopped and the signal sounded. Clothes were not dry so I set the dryer again, pushed the start buttom and dryer would not start up.
first check and see if the fuse in the breaker box has flipped or blowed. If that is not the problem then you need to check the fuse inside the dryer, it may need replacing. This fuse to some is known as the bullet fuse!!!!
Jul 17, 2011 | Dryers
Hotpoint ultima logic sensing condencer TDC62 is not drying clothes, it doesn't appear to be heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Dryers
Clothes dryer drum stops turning during drying cycle
your motor is going out , it doesn't have wenough to keep going.
Jun 26, 2009 | Dryers
Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Apr 21, 2009 | Dryers
Dryer works for few minutes then stops
clothes can open the door if door latch is weak, causing door opening and stopping the cycle, or a bad automatic sensor
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
66 people viewed this question
Top Dryers Experts
