Question about Onkyo Audio Players & Recorders
I need onkyo dxc-300 optical unit - Onkyo Audio Players & Recorders
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Jul 04, 2017 | Denon Audio Players & Recorders
No signal is received in the optical input of a 2000 ONKYO TXD 575 Receiver. Remote controller replacement for this unit too the model of the remote is RC-392M
Hi Ben please check the assignment of that port. The port could be bad. I checked several sites for a replacement remote and they are not available. Thank you Onkyo USA
Dec 29, 2016 | Onkyo Audio Players & Recorders
I cant get the surround sound to work after connecting the Samsung BluRay Player to my Onkyo reciever using a optical digital connection or directly with the HDMI cable ?
You will have to assign the optical input to the input you are using, so for instance if you have plugged the optical cable into opt 1 on the onkyo reciever and wish to use the DVD input on the onkyo reciever, you need to go into the set of the onkyo to digital assignments or in/out assignments, dependent on the model, and select OPT1 for the DVD input. You can find out how to exactly do this in the onkyo's manual under 'digital assignments' or 'input assignments'.
Dec 12, 2010 | Samsung BDC6500 BluRay Player
My Onkyo DV-C600 will not Load neither DVDs or CDs. It keeps flashing LOADING or Disc Error.
try cleaning the optics, with alcohol swab, if this dos not help you will need to replace the laser assembly. or and have further diagnostics performed on your unit.
Jan 28, 2010 | Onkyo DV-C600 Multi-disc DVD Player
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Mar 18, 2009 | Onkyo TX-DS595 Receiver
No audio from my PS3 through the Onkyo 5100 7.1
if you are using an HDMI cable dont expect sound to come out (even thought HDMI carries both audio and video) the onkyo HT-s5100's Receiver is the HT-r560. the 500 models of the onkyo receiver does not allow HDMI to carry both audio and video. it only allows the video signal to pass to the receiver.
if youre using optical for audio w/c is what you need then these are the steps you need to follow.
*first make sure that the optical connections are ok at the back of the receiver.
*make sure that your DIGITAL INPUT is set to either OPT1 or OPT2 whichever optical input you used to connect the optical cable.
*then go to your PS# settings : go to sound settings / audio moutput settings/ select digital out (optical).
then enjoy.....ü
Jan 27, 2009 | Onkyo HT-S5100 Theater System
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
Jan 24, 2009 | Onkyo Audio Players & Recorders
I hooked up a fiber optic cable directly from a samsung hdtv to my onkyo surround sound system. Sound, however, does not come out of the speakers. Also, I am running cable directly to the tv from the wall...
Make sure that the place it is plugged into the TV is an output and not an input for the fiber optic cable, and the place it is plugged into the Onkyo is an input and an output for the fiber optic cable. This can be connected backwards very easy. Then you want to make sure that the Onkyo is properly set on the right function to listen to the TV. Check your owners manual on how to set up the optical input and have it assigned to the function you are trying to use. Sometimes these type of receivers have an input mode button that you can set to "optical" or "analog" or "digital" or "auto". Try changing those settings after you make sure the TV optical is an "OUTPUT" and the optical on the Onkyo is a "INPUT".
After you have these thing set right you should be able to listen to it like this.
I hope this helps, if you need more help just reply back on this post, but please give more detail about the connectors and on the TV and the Onkyo, and about the digital input settings on the Onkyo. It would also help to know the model numbers of both the TV and the receiver. There is no way to check out what each of your devices are capable of doing without knowing the model numbers to look up the specs.
Sep 07, 2008 | Onkyo Audio Players & Recorders
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
27 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
