Question about Vacuums
Robovac S 28027 reviews and price .the p model with this no.not satisfied with side brushes breaking off after only 6 wks
Want to see the above how much plainer can i be
  • 5,412 Answers
By plainer do you mean ill-mannered ?
Posted on Dec 28, 2016
  • 5,630 Answers
Can you be a little bit more plainer!
Robovac p28027s this is updated model want price and reviews on it
Sorry this is not the consumers report website .
Dec 28, 2016 | Vacuums
Can I buy a dyson soft dusting brush connector?
Sure why not? Amazon even carry's one for $14.00 - see the reviews - people seem to love it! 4 out of 5 stars!
Aug 22, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
LG robovac stops
change belt
Dec 26, 2013 | LG Vacuums
Spin brushes not turning
Most all Hoover SteamVacs rely on a turbine to create suction and spin the brushes. The brush block (removable, just clips in) will have one of the 5 or 6 brushes with a stem inserted up and in the turbine. Hoover did a poor job sealing the hole that stem goes through and water and cleaner seep up to the lower bearing on the turbine and the bearing siezes. The turbine has a gear assembly inside! It is not easy to replace the turbine, especially the first time because what needs to be removed can be a head scratcher. However goes easier the second time. The turbine can be taken apart once out and I have used light grease to free up the bearing and gears but it's only a temporary fix. Different models have different part # turbines so pay attention when ordering the part. Need a work bench environment to do this. On occasion the brush block itself can get stuck because the brushes gear mesh together and the stemed brush drives them all. They can and do bind up with junk and do wear down and bind. If you can't turn all 5 or 6 brushes by spinning with your fingers on the stem, the block itself could need replacing. The block and brushes do come apart for cleaning but be careful because they are plastic clips on both halves of cover/retainer and can break.
Sep 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
How do I change the belt on a dirt devil ultra vision vacuum cleaner
I just changed mine and I will be blunt. First off, the design is **** on this vacume, secondly the belt was designed to break on the rusty carbon steel pully rod. Ok now that I've vented we will get down to business. On the bottom of the vacume you will find a plastic housing thats covering the brush. It will have 4 screws around the brush plus one above them. The housing itself is shaped like an L. Remove all the screws and expose the bare brush. This was not my case but there should be a belt holding the brush to a small steel pully rod in the top part of the L indention. If not then just locate an indention on the brush where the belt will be placed and look directly beneath that to find the pully rod (probably about 6 inches beneath the indention on the brush). wrap your new belt around the metal pully rod and then take out the brush. Wrap the other end of the belt around the indention on the brush and pull up hard and replace the brush in its vacume housing. This will take some effort as the belt has to be stretched. When finished replace the housing cover with the five screws and boom you're done.
Jan 10, 2011 | Dirt Devil Vision Turbo W/Bonus Upright...
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Mar 23, 2010 | Bissell 6594 PowerForce Bagless Upright...
I have a Eureka Altima and not sure how to change the belt?
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
new belt around motor shaft and
brush roll
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you replace the belt
Check for a pair of screws at the outer edge of the brush housing area. On this unit I believe the unscrew form above. Then look for any others on the bottom plate below the the brush. Belts can break or burn thru. If your s has burned, clean the burned rubber from the motor shaft before replacing. Spin the brush roll, if it rolls smoothly remove it , place the belt over the motor shaft, then onto the brush and use the brush to pull into place.Check for hair and thread buildup at the end caps of the brush. The nylon caps pop off for cleaning.
Sep 06, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
