Temp lights on FFU00 goes of every few hours turn off at mains they come back on but only for afew hpurs
5 Suggested Answers
  • 6 Answers
SOURCE: Blue screen on main display
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
Posted on Aug 10, 2009
  • 244 Answers
SOURCE: check engine light comes on when setting interior
a. check thermostat and temperature sending unit b. check coolant level! (this should be a.!)
start the engine ,let it warm up a little, take off radiator cap, should see coolant circulating in radiator- if it isn't after a reasonable amount of time, then your thermostat may be defective! if it is flowing, your temp. sensor may be bad- or, perhaps, a loose wiring connection.
these newer cars can make it difficult to actually see what's happening with the coolant, so no guarantees!
good luck!
Posted on Oct 02, 2009
  • 119 Answers
SOURCE: pilot light lights and stays lit until you turn
Sounds like this is the gas regulator giving the the problems, i would call a local plumber to service this . gas and flame is very dangerous.
Posted on Mar 28, 2010
  • 188 Answers
SOURCE: acer tv problem
Please refer the following link
http://751b3dfe.linkbucks.com
Posted on Jan 19, 2012
LG LED TV 55LN5600. Backlight goes off after maybe 30 minutes. The sound is on. picture is on (tested with flash light). Replacing power supply board did not fix the issue.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 04, 2017 | LG Televison & Video
Tv is a haier model#l42b1180 tv comes on left side not as bright then cuts off after afew minutes
Jun 19, 2016 | Haier Televison & Video
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 12, 2016 | Philips Televison & Video
Ge fridge controls not working
try unplugging it for a few minutes then plug back in see what happens
Feb 23, 2015 | GE Refrigerators
Why the warning message on citroen xsara picasso
Temp sensor is a common problem. Right hand side of the head - green plug if memory serves me correctly. Good luck
May 17, 2014 | 2001 Citroen Xsara
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
Cannot turn on Oven
your oven needs a new ignitor it has to draw 3 amps or more to open the gas valve (just because it glows doesnt mean its good) let me know how you make out
Feb 21, 2008 | Ovens
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
