Question about Miscellaneous
What is ideal gas? - Miscellaneous
91 4.0 6 cyl Rough ideal wont stay running. blue smoke
Blue smoke indicates engine oil being burnt, sounds like piston ring are knackered.
Aug 01, 2014 | 1991 Ford Explorer
A 89 suzuki sidekick ideal fast when cold when it warm up ideal slow down is this normal
Yes you car chokes itself and runs more gas and less air as the air expands more when cold which makes your car idle higher if it didn't do this it would actually die.
Dec 13, 2013 | Cars & Trucks
How to calculate volume
Use the Ideal Gas Law
PV=n RT
V=(nRT)/P
Use n=1.40 mol,
T=(273-4) K
P=1.20* 101325 Pa
The result will be in cubic meters. Convert that into liters.
1 m^3 =1000 L
I trust you can continue on your own.
Dec 04, 2013 | Office Equipment & Supplies
Ideal icons boiler code h1
ideal boiler instructions and manuals are downloadable from ideal :)
Sep 16, 2013 | Coleman 7990-319p Evcon Gas Furnace...
This is a colemon evcon electric furnace for mobile home the blower work fine just won't put out no more heat any ideals
when the fan is operating, is the fan switch on the thermostat in "on" or "auto" position? if it\'s in the \'auto\' position, then the stat is calling for heat ok. if so, you should check the safety controls for closure...i.e., the rollout switches (if there are any) and the high limit control, you should also measure the voltage at the gas valve. if you have 22 -27 volts at the gas valve, and you have all upstream gas open, and you have gas available (not shut off by gas company), but still no fire, then you probably have a defective gas valve. otherwise, if you have a wiring diagram, it should be easy to find the problem.
Jan 25, 2013 | Heating & Cooling
The volume of gas sample is 100ml when the temperature, is 27 degrees c what will be the volume of the gas at 37degrees c if the barometer reading remains the same?
To solve this problem you can use the physical law of ***-Lussac, a special case of the Ideal Gas Law for isobaric processes. For an ideal gas, the quotient V / T is a constant, if the gas pressure is constant. V = volume of the gas, T = temperature of the gas in degrees Kelvin.
  • 27°C = ( 273.15 + 27 ) °K = 300.15 °K
  • 37°C = ( 273.15 + 37 ) °K = 310.15 °K
According to the law of ***-Lussac, V1 / T1 = V2 / T2 = const., we get an equation (V1 = 100ml, T1 = 300.15 °K, V2 is the unknown volume, T2 = 310.15 °K):
  • 100 ml / 300.15 °K = V2 / 310.15 °K
  • => V2 = 100 ml × 310.15 °K / 300.15 °K = 103.33 ml
Jan 14, 2011 | Panasonic Computers & Internet
1988 jeep cherokee 4x4 4.0L ruff ideal/no power
try and repalce the fuel pump it sounds like it s getting weak
Mar 03, 2009 | 1988 Jeep Cherokee
My 1991 pontiac lemans wont ideal
check your fuel filter is clean, and may need to clean idle jet on carburettor
Feb 17, 2009 | 1991 Pontiac LeMans
Ideal gasoline
87 octane is ideal for your accent.
It's a little commuter car. It's designed to save you money.
Anything over 87 is just a waste of money, UNLESS your engine is knocking at 87. Then you should step up to the next highest grade.
89 is a made up octane. It's just a mix of the lowest grade and the highest grade. I used to work at a mobil gas station for a year, and the only grades i knew wer 87 and 93, but 89 was an available option. it's just a way for oil companies to benefit off of ignorance.
91 and 93 is for high performance engines, turbo-induction, superchargers, that sort of stuff.
you should be fine sticking with the 87 though, but move up to "89 octane" or 91/93 if your engine knocks a lot.
hope this helps.
Feb 13, 2009 | Hyundai Motor 1998 Accent
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
