Question about Samsung Refrigerators
Samsung SR-S2028CVW water is not dispensing. Any ideas?
3 Suggested Answers
  • 219 Answers
SOURCE: Cant reset temp after appliance was switched off
sounds like a bad board unplug for few minutes see if it will reset if not will need to be serviced
Posted on Mar 19, 2009
SOURCE: i have a samsung SR-S2028cvw American style fridge
Try hoovering the cooling rad on the back of the fridge freezer, as this tend to clog up with dust and other matter, which reduces the cooling efficiency
Posted on Feb 28, 2010
Why water to icemaker , none to water dispenser , replaced water inlet valve fghs2655pf1 or 4a32520097
Refrigerator Not Making Ice? Water Inlet Valve Test - Fridge ...
? 2:47
https://www.youtube.com/watch?v=aXIX73EI1Z4
May 15, 2012 - Uploaded by RepairClinic.com
This video demonstrates how to test a water inlet valve on a refrigerator. ... Ice maker or water dispenser not ...
Refrigerator Ice And Water Dispenser Not Working - Repair ...
www.repairclinic.com/...---/Refrigerator-ice-and-water-dispenser-not-wo...
How It Works: Refrigerators · How It Works: Refrigerator Icemakers · How It Works: ... Most Frequent Causes for Refrigerator ice and water dispenser not working.
Nov 18, 2015 | Refrigerators
I have a samsung SR-S2028cvw American style fridge freezer. The temperature on the dials are at the coolest but both the fridge and freezer are warming up to the warmest temperature before the motor kicks...
Feb 28, 2010 | Samsung Refrigerators
American fridge/freezer - fridge stopped cooling, freezer side ok
Have you pulled out the refrigerator and cleaned or used a vacum cleaner to get out the dirt and dust off the back of the coils, or if the coils are underneath, you need to get an inexpensive appliance brush for fridge, and clean the coils under the fridge, pull off the panel on the front bottom of the fridge, get a flash light and look to see if the coils are covered in dust....may just need to vacum and use appliance brush underneath...this should be done at least one a year, you will notice your fridge running much better and cooling back to normal.......hope this helps......
Jan 05, 2010 | Refrigerators
Samsung side by side fridge freezer with water and ice dispenser the ice dispenser works fine but the water dispenser dose'nt, I have changed the water valve, It worked for a while but its not working now....
You likely have a blockage in the line somewhere. If the water valve is sending water to the icemaker, it should be sending it to the water dispenser.
Try removing the water dispenser line from the water valve and run something through it to try to open it up. I had this problem several years ago and used a length of plastic weedeater line to open it up.
Oct 20, 2009 | Refrigerators
Mar 18, 2009 | Refrigerators
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
I have a Samsung SR-S2028CSS side by side Fridge Freezer with an icemaker water dispenser. The freezer is run at -23 degrees and the fridge at 2 degrees. Recently the ice, having been made in the icemaker,...
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Apr 08, 2008 | Refrigerators
Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Jan 26, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
