Question about VIA Computers & Internet
My Hanns G HG281D monitor keeps going through a standby, on and then standby loop even if its not connected to the PC via the monitors HDMI cable.Any ideas would be appreciated. Cheers
  • 105 Answers
SOURCE: hdmi to dvi
This message may occur if the signal from the video adapter exceeds the scan range of the monitor (monitor not HD enabled).
The video adapter setting on PS3 for updating the screen (the refresh rate) is incompatible with the monitor.
Posted on Mar 28, 2008
SOURCE: LCD Monitor
Mine had the same problem. Sometimes it worked, sometimes it didnt. It really annoyed me. I tested my PC on another monitor, it was fine. I checked my monitor on another PC, it worked fine. We eventually found out it was just the VGA cable. So i would advise just trying another VGA or DVI cable and see if it works.
Hope this helps. Good Luck
Posted on Apr 15, 2008
Fix-4U
  • 293 Answers
SOURCE: I just got a HANNS.G
Hi...there,
It's seems you got a busted backlight inverter...
Posted on Dec 01, 2008
asthanarht
  • 258 Answers
SOURCE: My monitor says cable not connected
If it like my monitor, same hookups as yours, then when you want to use the hdmi port you need to disconnect the dvi cable. The monitor cannot read from hdmi & dvi when both are connected, Try this & see if your PS3 works. Good luck
Posted on Jul 03, 2009
  • 58 Answers
SOURCE: I have a hanns g hg281d just over a year old. It
your monitors pwr supply has been worn down, you need a new one (most just get a new monitor) in order to avoid this problem in the future, make sure the screen is placed in a vell ventilated area, and that you turn the power off every once in a while.
Posted on Sep 26, 2010
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Im having issues with the hanns-g hg281d. my screen is always faintly flickering, especially when the screen is on darker colors
i was having same issue.i would turn off monitor for 10 secs. then turn on .and it would not happen for a while .i went to i cable and it now rearly ever happens.
i use this as a external monitor for my laptop for 6 mons.now.
Jan 04, 2011 | Hannspree HW191D LCD Monitor
I have a hanns g hg281d just over a year old. It has started blinking on and off several times when it comes out of sleep mode in the am. Is the power supply going bad? I have talked to other people having...
Sep 26, 2010 | Hanns.G Corporation 27.5" Widescreen...
Have a green rectangle about 2 inches by 5 inches in center of screen with yellow letters that say, input signal mout of range. It is A hanns g hg281d monitor
Restart your computer,
and keep hitting the F8 key until a "start-up" menu
(white text over a black background) is displayed.
Choose "Safe Mode" and let Windows start.
Reset the screen-resolution to 800-by-600, and 60 Hertz refresh-rate.
Restart your computer, normally,
and then "tweak" the screen-resolution and refresh-rates that are "optimal" for your monitor.
Aug 09, 2010 | Computers & Internet
How to connect 3 LCD monitors to a computer
Some cards can send 2 outputs that is split by the cable, which is connected to 2 monitors. Generally speaking though, most just split the image up
If you're not sure if your output supports multiple monitors off one output, it's almost certain it doesn't.
There is USB 2.0 to DVI, HDMI and VGA Multi-Display Adapter
resolutions of up to 1600 x 1200 Allows for effortless multitasking
Jan 05, 2010 | Dell DimensionTM E520 PC Desktop
Trying to hook up to ps3 using HDMI to DVI cable with Hanns G 174D monitor. CAn only see blank screen, any solutions?
Hook up the PS3 so you can see the screen. Then go into the display settings and lower it to the lowest resolution settings. Then try connecting it again.
Sep 07, 2009 | Computers & Internet
Monitor has just stopped working
perhaps a repair shop. most electronic devices fail this way
Oct 06, 2017 | Hanns.G Corporation HX191DP LCD Monitor
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
Computers & Internet Logo
75 people viewed this question
Top VIA Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
jason
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
