Question about Epson Stylus DX4450 All-In-One InkJet Printer
Where is the cleaning button on my epsom stylus dx4450
  • 148 Answers
SOURCE: epsom dx4450 how to change ink cartridge
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
Posted on Sep 16, 2008
  • 404 Answers
SOURCE: need manual for Epsom stylus sx200
Have you tried or if no luck there try my favourite site if it isn't there there will be a link, Cnet's never failed me.
Press the blue button if satisfied with my Free effort, Thank You!
Paul 'W' U.K.
Posted on Feb 05, 2009
cns assoc
  • 677 Answers
SOURCE: epson stylus DX4450 i have changed the ink and the
Did you use Epson Genuine Cartridges?
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 23, 2010
  • 977 Answers
SOURCE: how to change ink on a epsom stylus 215 printer
Hi Eileen!
Use the instructions here to change your printer's ink cartridges.
(Use the arrows on top to switch pages until you get to "Remove and Install Cartridges").
Best regards,
Posted on May 10, 2010
Testimonial: "thanks for your help"
  • 231 Answers
SOURCE: Cleaning ink Head Printer/Scanner for Epson Stylus
Here is a direct link to show you how to clean the Ink Head. Copy and paste web address into your address bar. Good Luck
Posted on Jan 26, 2011
How to clean a epsom dx4450 printer
Depends where you want to clean it. It's a good idea to wipe the roller with a damp cloth sometimes, but if it is the print head then there is an article here:
May 12, 2014 | Epson Stylus CX6400 All-In-One InkJet...
I have a Epson stylus DX4450, and the scanner doesn't read anymore. Is it possible to reset it?
Try disconnecting the power supply from the electrical outlet and the usb connection to the computer for 10 full minutes and then reconnect both. This usually works.
Feb 08, 2012 | Epson Stylus DX4450 All-In-One InkJet...
How can i open an epson dx4450 so i can cleean it's print head?
try cleaning it from maintenance menu
in case i had help you pls vote me
Nov 05, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Which is the cleaning button
Open this weblink click on Online Support & Mannuals - There Information about your problems, open web link
Feb 02, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Hello i changed the ink in my epson stylus dx4450 however the ink light is still on and it still wont print. i tried turning it off at the plug but still wont work
It seems that the connection on the cartridge and the printer are not proper. Remove the cartridge and clean the connectors on the cartridge and the printer. Also remove the tape on the print head.
Aug 28, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Missing lines when i print
realigning your new ink... thats all... or clean the heads...
Jun 16, 2009 | Epson Stylus DX4450 All-In-One InkJet...
My epsom DX4450 only prints in black. Have cleaned heads done nozzle check and reinstalled it twice. Anybody help me
have you gone into the print setup >printer>properties>paper/quality and selected colour printing there ?? hope this helps regards JIm
Apr 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My epsom DX4450 status bar is in german
you would need to uninstall driver and reinstall English drivers
Mar 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epsom stylus all in one dx7450
press 'Control' + 'P' on a page (as tho you want to print)
click 'Maintenance'
there you'll find various options to clean heads etc, that should do it. tho it does deplete your inks considerably each attempt. & you'll probably find it needs more than one clean.Good luck!
Jun 08, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus DX4450 All-In-One InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
