There's a port on the left side of my presario c6o1 with the picture of a padlock on it, i need to know what it's for
  • 6 Answers
This is for a laptop lock. It looks like a bicycle lock but made primarily for electronics. Google "Kensington Lock." Not terribly useful as the cables are a little thin, but does provide some protection if you are in a public place and won't be straying far from the laptop.
Posted on Dec 28, 2016
Keyboard has a padlock image on a key. what is that?
press FN (function key) button plus closed padlock -- it will lock keyboard -- to unlock press FN key + open padlock
Oct 23, 2011 | Compaq Presario CQ62-215DX Laptop
How do i connect compaq presario x1000 to external monitor
Hi Judy,
The Compaq Presario x1000 notebook offers connections for external displays at the rear below the screen hinge as show in the picture below:
Identifying the back from left to right: Ventilation slots, External VGA Port, S-Video Port, USB Port, USB Port, RJ-45 Network Jack, RJ-11 Telephone Jack, Parallel Printer Port, USB Port and 1394 (a.k.a. "Firewire") Port.
You can connect a VGA monitor to the VGA port (blue colored jack) very easily. Any analog VGA monitor should readily connect to it. Additionally, the x1000 can output its display to TV or other monitor that accepts "S-Video" signals. An "S-Video" cable will be needed to connect between the "S-Video" jacks on the notebook (next to the VGA Port) and one on the TV. It is important to note that not all TVs support both or either "S-Video" or VGA inputs. When ever the there is a choice of using S-Video or VGA on a TV or monitor, the VGA will provide the best looking picture, and should be used.
I hope this helps and good luck! Please rate my reply - thanks.
Oct 03, 2011 | Compaq Presario X1000 Notebook
Do all compaq presario cq60 have a memory slot?
It has a memory card slot (left-side towards the front), but your particular memory card might be too big for the slot. There are several different variations of memory cards out now. Of course the newer the variation, the smaller that card is. This laptop is fairly new so it might not be compatible with your memory card. Does your camera have a USB cable for transferring pictures? If so, then just use that.
Mar 13, 2010 | Compaq Presario CQ60-220US PC Laptop
I have a Compaq Presario CQ60-215DX Notebook PC. For some reason it shuts down without warning. What can cause it to do that?
Overheating...
Your going to need to clean the fan/heatsink assembly..
On the cq60, this means complete disassembly of all parts and components...in order to get to the fan properly, the motherboard will need to be removed..
Remove All screws on the underside of Laptop, Remove Covers..(hard drive,RAM,Wifi).. Pull Out CDrom....Remove the 3 screws from cdrom area.....Flip Over.. Open Screen, Pull Media Strip (above Keyboard) Away from Laptop... Be carefull Here, There are Fragile ribbon cables attached to this on the left underside ..
Now Unscrew Keyboard Screws And Pull Keyboard away, THere's a ribbon cable here too attached to the motherboard,, Unlock the ribbon cable at the motherboard port(tab on each side pulls forward).. Remove Palmrest Screws.. Pull the Wifi Cables through the Motherboard upperside, Detach any plug/wires... Unscrew Screen Hinge Posts and pull screen away... Remove the 1 screw holding the rear strip of plastic---unsnap the plastic strip at back end of palmrest area... Pull palmrest away... Unscrew The Media Card Bay and the CDrom Port Board(left side)....
Remove the 2 motherboard screws on the bottom left side front...
Unplug the long cable port on the front underside of motherboard right in the middle....
Lift up the motherboard slightly.. pulling it up from the left rear side..... You will see the DC Jack Power Cable Right There Under The Motherboard... This Needs To Be Unplugged...--Pull The Motherboard Up About 2 inches and reach under to unplug the DC Jack Wire Port Plug...and the usb plug wire...
Now continue to remove motherboard
Flip Over And Remove Heatsink Fan Assembly... Unplug Fan... Disassemble Fan And Clean FAn And Heatsink Fins...
Nov 28, 2009 | Compaq Presario Notebook
Presario A900 A976TU USB Port Issues
It may be that you need to update your drivers
Start here
Microsoft's built in drivers may not be making best use of your hardware and causing the problem you describe.
The driver may be for the motherboard and not usb.
Either way it provided you with the opportunity to update other drivers too
Aug 24, 2009 | Compaq Computers & Internet
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
How to remove battery from compaq presario 2100
Hello there,
There should also be a switch to lock or unlock the battery.
It will show a little padlock. Turn it to the symbol with the padlock open, then pull the slide release and the battery should come out.
Thanks,
Lolita
Apr 11, 2008 | Compaq Presario 2100T Notebook
Philips mp3 1GB SA3114/97 padlock symbol?
Slide the padlock lever on the left side from the up/on position to the down/off position
Mar 12, 2008 | Philips Audio Players & Recorders
Picture of a padlock?
The HOLD switch is activated. This is a feature that allows you to lock all the buttons, so you don't switch it on & off accidentally.
Flick the switch on the side!
Jan 08, 2008 | SanDisk Sansa c200 MP3 Player
Camera is locked
you must unlock the memory card, take out the memory card and there will be a little switch on the side, move the switch to the opposite position and the camera should work just fine, if this doesn't work, let me know
Feb 18, 2007 | Pentax Optio M10 Digital Camera
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
