Question about Siemens Washing Machines
Siemens dish washer SM6P1s during cycle display goes off and machine stops then starts up at the point it stoped goes through on off stages and completes the job several hours later instead two hours
  • 1462 Answers
SOURCE: Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Posted on Jun 19, 2007
  • 22 Answers
SOURCE: bosch dish washer SGS56E02GB
anti flood device has been activated, this means you have water in the base of appliance. most likely a leak, or if you have been using 3 in 1 tablets, and rinse aid this will over foam appliance and foams leaks into base.. try tipping d/w back to let water out of base..then try d/w again... if anti flood activates again...call an engineer.. ps check big nut that secures salt container to base of d/w, it can come loose which will cause water to leak into base ally
Posted on Jul 02, 2007
natengel
  • 19 Answers
SOURCE: Washer stopped in mid-cycle and is full of water. I can restart the cycle, but
if it stops at #6 u need to change timer and motor
Posted on Oct 31, 2007
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
SOURCE: Washer pauses during spin cycle
Check the filter. I have the same problem and I found an string (slip) in the filter. The filter is back of the front pannel (under the door).
Posted on Oct 02, 2008
Siemens avantgarde washing machin stopping at rinse stage
Does the washer pump out the water after the wash cycle? If not then check the drain lines coming from the pump to make sure that they are clear. Your pump not pumping will cause the machine to stop working as well
Mar 23, 2014 | Siemens Washing Machines
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
As soon as the machine is on an error message of 3E appears and the machine stops
3E - MOTOR RESTRICTION ERROR
Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 14, 2010 | Samsung WF337AA Front Load Washer
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Siemens stops without going into the spin cycle
when it stops is there and f:XX error code on the display? were XX is a number.
Jul 18, 2009 | Siemens WM14S794GB Front Load Washer
Display goes blank at certain points during wash cycle
replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Washing machine
Check pump fiter and pump.
Jul 22, 2008 | Zanussi ZJ1217 Front Load Washer
When the washer go s on rinse the prewash flashes Problem
Mine has been doing the same ... each time it goes to the next part of the cycle the red light flashes but the machine doesn't do anything ... so up till I have been able to get the machine moving to the next stage by pressing the "Start" button ... unfortunately the machine will pause on each stage - meaning I have to press "Start" at each stage!
Dec 15, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
