Is str 6654 with 3pin in and 2pin out the same with 3pin out and 2pin in thanx
Please tell me how to remove the fan from the receiver it has stopped working causing the unit to go into a Protect-Fan mode thanx for any help John
hello the reason the fan has stop working may be down to the output transistor shorted out or a swelled capacitor
Sep 12, 2010 | Sony STR-DE945 Receiver
2pin male connector of the motherboard (261671-001) purpose?
the switching power supplies are fun, by 2 pin plug is that from the AC side or computer side?
from AC side its easy enought to go buy another plug thought it should have come with one.
i cant remember any 2 pin plugs on the computer side and i have taken quite a few of these apart. there is a four pin plug...
wire colors,
yellow 12 volt
black ground
red 5 volt,
if the old supply was any of those colors you can desolder from the old supply and re solder it onto the new supply. if it was another color then i would suspect a random signal wire or cutout, keep you from frying yourself with the case open... try plugging up the new supply and turning on the computer if it runs why worry about it?
Jun 10, 2010 | Compaq (261671-001) Motherboard
2002 Hyundai XG350L Pwr str line blown need that section illustrated - thanx Karl 40222
Just had mine replaced for $173.00
Sep 25, 2009 | 2002 Hyundai XG350
Sony STR-DE445 protect displayed
It sounds like a bad solder connection. It just needs to be soldered up, if you take it into a shop just tell them it doesn't need any new parts, it just needs to be soldered up.
Or, if you can solder it yourself, or know someone that can, that would be much easier.
Aug 04, 2008 | Sony STR-DE445 Receiver
HDMI Input not recognized
With the power on, load a DVD and wait until it starts playing the movie. Press "Voutput" button - HDMI output (480, 720, 1080) will light upt and you should have video.
Dec 27, 2007 | Toshiba D-R5 DVD Recorder
WIN VISTA Ultimate does support Philips SAA7130 TV Tuner/FM Radio/Video...
I couldn't get to work in Vista. So I tried in linux and My SAA7130 is working great in Ubuntu linux. bye vista.
Dec 26, 2007 | Philips TV Tuner Video Capture PCI Card -...
About flash 8
Here is the small sample code. This will convert the lower case letter to upper case letter from left to right character by character.
TextField.prototype.caseAnimation = function(str) {
    var tf = this;
    tf.upperIx = 0;
    tf.str = str;
    var id = setInterval(moveUppercaseLetter, 100);
    function moveUppercaseLetter() {
        var str1 = tf.str.slice(0, tf.upperIx);
        var str2 = tf.str.charAt(tf.upperIx).toUpperCase();
        var str3 = tf.str.slice(tf.upperIx+1, tf.str.length);
        tf.str = str1+str2+str3;
        tf.text = tf.str;
        tf.str = tf.str.toLowerCase();
        if (tf.upperIx>tf.str.length-1) {
            tf.upperIx = 0;
this.createTextField("animated_txt", 1000, 0, 0, 500, 25);
animated_txt.setNewTextFormat(new TextFormat("_typewriter", 16));
animated_txt.caseAnimation("pack my box with five dozen liquor jugs");
Oct 18, 2007 | Macromedia Flash MX
Right channel is completely gone
I had a smilar problem a few years ago where myfront right speaker had a distortion and i gae it to a Sony dealer and they say the IC for that channel went bad. So you could checked
Feb 28, 2007 | Sony STR-DA90ESG
