Conia ca12007 air conditioner won't operate by remote control However is going after pressing reset button manually on the actual unit. Temp is set on 24. Can this be manually changed at the unit.
    New Friend:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Check remote batteries
Testimonial: "That was the first thing we did. Brand new ones put in but still wont connect with the unit"
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
i can send to u
Posted on Mar 16, 2008
  • 236 Answers
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
  • 10 Answers
SOURCE: I have a model AR DL10 remote for a Fujitsu air
After changing the batteries you have to depress the RST button and if the remote has the abcd slide switch ensure it is set to A.
Posted on Jul 15, 2010
Testimonial: "THANKS"
Can the unit operate without the remote control
Yes, by pressing the power button on the unit. It is factory set to cool to 68 degrees and maintain that temperature. To access any other settings you must use the remote control. The part # for the remote is CRMC-A750JBEZ
Aug 14, 2013 | Sharp CV10NH Air Conditioner
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
My airwell aircon won't respond to my remote, my
HOW TO INSTALL BATTERIES Remove the lid in the rear part of the remote control unit.
Insert two AAA alkaline batteries of 1,5 V-DC. Make sure the batteries point in the direction marked in the battery compartment.
The batteries last about six months. Depending on how much you use the remote control unit. Remove the batteries if you do not use the remote control unit for more than one month. Press the +, -, SET and CLEAR buttons together after batteries replacement.
(This operation allows you to reset correctly all the programs. The remote control unit is to be set up again).Replace the batteries when the remote control unit lamp fails to light, or when the air conditioner does not receive the remote control unit signals.
The batteries of the remote control contain polluted substances exhausted batteries must be disposed according to the laws in force.
Jan 12, 2013 | Heating & Cooling
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
I cant get cooling from my air con,model-emailair WS066H,but I do not have a remote control for it,can i control it manually.
Only in some models, there is an option to operate manual. Check near indoor display. If there is button press it. But you can't change temp setting and mode as you like.So, It's advisable get new remote.
Dec 29, 2010 | Heating & Cooling
Need a conia airconditer remote control here in Australia. We have 2 split systems that use the same remote. Models CA 24003 & CA 3003. Conia have gone bust here and we can't get a replacement remote....
i had the same problem and i managed to find a universal remote control from JARCAR Electronics. Model of the remote: Digitech AR-1729. It doesn't list Conia as compatible but I managed to gain control of the aircon using the code: 291. For some reason when you press the power button on the remote, it's like your double pressing the on button so the aircon switches on and off quickly. You need to press the power button on the remote quickly and move it from reception before it powers down the unit again. At least I have control of the aircon again and I don't have to put up with these humid hot days in melbourne... Good Luck.
Jan 01, 2010 | Heating & Cooling
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
Conia CA1800 wont heat
there should be a mode button, press it until you see the sun sign
Jul 09, 2009 | Heating & Cooling
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
75 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
