Question about Kitchen Ranges
Stove pilot is lit but will not turn on - Kitchen Ranges
5 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: The oven pilot to our
have you done testing and checking the unit, it seems that your problem was on the thermal fuse, and this part need to be replaced if you find it burned or busted
Posted on Aug 07, 2008
2coolrick
  • 560 Answers
SOURCE: I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
Posted on Aug 12, 2009
  • 3 Answers
SOURCE: I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Posted on Oct 16, 2009
AndrexT
  • 14824 Answers
SOURCE: Cannot turn burner to pilot light
Is the oven knob spinning? Pull the knob off and turn it with pliers.
The stove also has a connection at the rear of it that you can with turn off or twist out the pipe with has a self sealing bayonet fitting.
Posted on Jan 27, 2016
Testimonial: "We took the knob off but are unable to turn the knob it will not push in to turn it to the pilot light. We have searched high and low for shut off valve what do you mean there is a connection at the back you can turn off?"
My jotul 200 direct vent gas stove pilot light won't stay lit. The pilot lights normally, and fires when the thermostat calls for heat. But when it turns off the pilot goes out as well. We cleaned ou
There's a little screw that adjusts the pilot light. It is usually on the block with all the other valves. Follow the pilot lite supply line to where the screw probably is located.
Nov 22, 2013 | Stoves Heating & Cooling
After the pilot is lit, and you turn the stove on say 5, when it reaches the desired heat range it will turn off. But it turns the pilot light off too. You have to re-lit and start all over. thanks
i would replace the thermocouple
a very simple and straightforwrd repair
you can buy most thermocoupples at any hardware or homedepot type store
Oct 13, 2009 | Heating & Cooling
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Aug 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Holiday Stove Pilot Light won't stay lit.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
Jun 16, 2009 | Cooktops
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Propane was turned off for unrelated problem propane turned back on stove will not lite
If your stove has a standing pilot, it will need to be re-lit.
If this does not help, state the model of your stove.
Apr 28, 2009 | Kitchen Ranges
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
