Question about Refrigerators
Auger motor works fine most of time but randomaly wants to run back wards for a cycle ?
This is a quad fire pellet stove not a ice.maker
mrgreenz
  • 962 Answers
SOURCE: My pellet stove will start
You need to replace the auger motor. Go to fasco .com they may have one. Or enco.com I have a pellet stove and i have replaced both the auger motor and the motor that turns the hopper.
Posted on Nov 20, 2008
protek480
  • 1723 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
protek480
  • 1723 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1723 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
SOURCE: GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Posted on Jul 24, 2009
No flame. The auger works fine and the pellets are feeding in. There is no fire to burn them.
Do you have a user's manual? Most pellet stoves need to be lit before starting the auger to sustain the fire.
Feb 10, 2017 | Cars & Trucks
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
How do i fix ager on my pellet stove?
Hello Ethan, First I would uncouple and remove the auger motor from the auger shaft. Next turn the stove on to see if the auger motor turns. If it does turn, try to hold the motor shaft with your hand to determine if the motor has sufficient torque to turn the auger. If motor seems to be strong enough , use a pair of pliers or a vise grips and try to rotate the auger shaft. If the auger will not turn, it might be clogged up with pellets or pellet dust. The clog will have to be removed. If that is the case, I think the gears in the motor are stripped and a new motor is in order. Note: Damp pellets swell up and turn hard as concrete when they dry out.
Dec 06, 2013 | Home
Pellet stove
vacuum switch helps all to work and power supply if more than 2 bends in the exhaust can b a problem to there is a intake air lever on the back of some that allow more or less vac pressure in to the chamber auger will not turn if door is open to create the vacume
Dec 02, 2013 | Heating & Cooling
Pinnacle Pellet stove augre gets stuck
hmm, could be low power to the motor, heavier power cord, or it's possible the auger needs new bushing/bearings, wiggle the auger to see if it has any play in it OR it's fussy about the size of pellets it made to feed. please send pictures and or results.
Jay
Jun 08, 2017 | Pool & Spa
Combustion fan isn't running
Ther is a guy names Murphy that it resposible for that. Go back through the steps you used to change the auger motor and see if maybe there was a wire left out or if the combustion motor is also out. What caused the outage? If a voltage spike, it could have taken them both out. The only other thing I can think of is a main switch somewhere. Good luck...Lee
Nov 14, 2009 | Napoleon Auburn Pellet Stove Heater
My pellet stove will start but the auger will not drop pellets. What should I do.
Nov 20, 2008 | Kitchen Ranges
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
