Question about Retail Supplies
My points come up on my screen but on the opponents it registers as zero
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Jun 20, 2014 | Samsung SAM4s ER-650 Cash Register
Is Farkle rigged?
arkle Live is a dice game played by one or two players over the Internet. The players take turns rolling the dice, with the objective of collecting 5,000 or 10,000 points quicker than their opponent in an ONLINE multiplayer game or reach a target score from 5,000 to 10,000 in 10 rounds in a solo game.
Each player's turn starts by rolling six dice to score points. As long as they roll scoring combinations, they can roll the remaining dice, or collect their points.
If your roll does not score any points, you get a 'FARKLE', losing all points accumulated for that turn.
If the player manages to score on all six dice, they get a 'Bonus Round' and may choose to roll all six dice again or collect the points.
Dec 19, 2013 | Facebook Computers & Internet
What are the rules of Backgamon?
Backgammon playing pieces are known variously as checkers, draughts, stones, men, counters, pawns, discs, or chips.
The objective is to remove (bear off) all of one's own checkers from the board before one's opponent can do the same. The checkers are scattered at first and may be blocked or hit by the opponent. As the playing time for each individual game is short, it is often played in matches, where victory is awarded to the first player to reach a certain number of points.
Jan 17, 2013 | Games
How do you score points using a sabre sword in fencing?
Points are scored by hitting anywhere on your opponents body above the waist with any part of the blade.
Aug 19, 2012 | Sport & Outdoor - Others
In fencing, what kind of sword is a foil?
A foil is a light, flexible sword. Hits on your opponents arms, legs and head do not count when fencing with a foil. You must strike by plunging the point of the sword at your opponents trunk.
What are the ways a wrestler can score points during a match?
There are 5 ways in which a wrestler can scorepoints in a fight. First, taking down the opponent to the mat and controllinghim (Takedown- 2 points). Second, when a wrestler either gets away or goes backto his neutral position after being down on the mat. (escape- 1 point). Third, whenthe wrestler is able to gain control of the opponent after being down (reverse-2-points). Fourth, near fall (2-3 points) is when you nearly get your opponentpinned. Fifth, you receive points if your opponent commits one of theviolations (illegal holds, technical violations etc.)
Aug 06, 2012 | Wrestling
What are the rules of Air Hockey?
Here are some basic rules as defined by the USAA:
  • A face-off or coin toss decides which player gets the first possession of the puck.
  • The first person to score 7 points by shooting the puck into the opponent's goal wins the game. When the puck breaks the horizontal plane inside the goal, a point is counted, whether or not captured by the electronic scoring device.
  • Once the puck is on a certain player's side of the center line, he/she has 7 seconds to hit the puck back across the center line. Otherwise a foul is committed and the opponent receives possession of the puck.
  • Placing one's mallet on top of the puck, known as topping, is a foul. Here the opponent receives possession of the puck.
  • A player cannot touch or strike the puck with any part of his/her body or with any object other than the mallet. Doing so causes a foul and possession changes hands.
  • If the puck is on a clear path into the goal and the player stops it with anything other than the mallet, this is goaltending. Here the opponent receives a free shot.
  • Hitting the puck when it is on the opposite side of the center line, or crossing the center line completely with one's mallet causes a foul. Here the opponent receives possession of the puck.
  • Red lines in the air hockey should not be crossed by the air hockey mallet. (Catalan Champion Chip)
  • If there is a red line on the goals, it means that you cannot keep the air hockey mallet behind the red line. (Catalan Champion Chip)
  • If the puck leaves the table, a foul is called on the player that caused the puck to go out of play due to offensive motion and the opposing player gets possession of the puck. Generally, when a player causes the puck to leave the table with a forward motion of the mallet, even defensively (known as charging), the foul is charged on them. An out of play foul results in the opponent receiving possession of the puck.
  • The players playing cannot touch the puck at any time during pl ay, but if one player scores they can put the puck in loser's side.
Jul 25, 2012 | Sport & Outdoor - Others
How do I reset the grand totals to zero on my sharp cash register model XE - A406
Go to PGR, hit tm/sbtl, then hit 64 (black keys) @10 (black keys again), tm/sbtl. Then go to x1/z1 and hit decimal point and then ca/at/ns. Do the same with x2/z2.
Oct 04, 2010 | Sharp XE-A402 Electronic Cash Register
How do you win an inferno match?
Divas bannedInferno Match 1v1 only A temperature meter in the bottom-left starts at 100 degrees. All moves will raise the temperature slightly, based on damage. At 300 degrees, ringside will flare up for about 15 seconds, at which point you must drag your opponent to the ropes. If you fail (and you probably will if your opponent doesn't have red damage), the temperature will reset back to 200 (not 100) degrees
Nov 08, 2009 | THQ WWE Smackdown Vs Raw 2009
Retail Supplies Logo
41 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
