Question about Dishwashers
Hi, Is the dish washer suppose to stop automatically after each cycle or do I need to manually switch it off after certain time?
  • 57 Answers
SOURCE: Washer does not switch to the next cycle automatically
Hi I would check the water valves
Posted on Jul 18, 2008
  • 639 Answers
SOURCE: Issue with switching to rinse cycle automatically.
Dear G.Arnold,
ngfam at you service
If you are under warranty it's FREE
Sounds like you need service! no cost to you!!!!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS.Before you sign off!
Posted on Aug 26, 2008
  • 163 Answers
SOURCE: Timer problem?
HI!!! You seem to have a problem with your timer..Good luck..If it stops and then you have to start it up then change your timer..Good luckk.
Posted on Jan 21, 2009
  • 228 Answers
SOURCE: Hi, we have a Classixx 1200. It will not switch
Posted on Sep 10, 2009
  • 1891 Answers
SOURCE: -Washer Lid Switch 3949247 (3949237) for WhirlpooI
why did you change sw/ did washer not spin ? or same problem . you may have a shorted of faulty ( new ) sw . just because its new doesn't make it good / ck with ohm meter .. if the problem is same as before sw installed the we need to lok at a different problem . like ( timer ) or wiriing . ) mm give me some feed back and wi can go / and model # brand .. . help is on it way .. mm
Posted on Dec 12, 2009
My GE 15 cycle heavy duty plus washer the water keep running in the rinse cycle
Hum the water inlet valve may be going out or defective, have u noticed any water in tub at bottom when machine is not in use or after a day or so? check it with multimeter. Another suspect could be a bad timer sticking on rinse cycle, or a bad water pressure switch, which is suppose to shut water off at certain water level then start the agitation? In other words when in rinse and water is draining, the pressure switch continues to read low and opens to keep the water flowing to replace water that is lost? Need a multimeter test on all of them
Sep 26, 2014 | Washing Machines
Hi my classique dish washer won't open,it is full with dishes ,how can i get in.thanks
f your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram attached.God bless you
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Apr 05, 2013 | Dishwashers
I have a ADP5000MT, when I start a cycle it begins but after 5 mins switches to the bottom option - the =30''V symbol button and keeps flashing .. I cant find my manual
CODES: The Express program light Keeps flashing quickly
MEANINGS: Longer inlet time
Possible Cause: Faucets is not opened, or water intake is restricted, or water pressure is to low.
Jan 16, 2013 | Whirlpool Dishwashers
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
Dish washer \does not rinse good leaves white flim
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
The water won't automatically stop flowing through
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It need replacing.
Sep 03, 2009 | Whirlpool LSB6200KQ Top Load Washer
Hobart Dishwasher
I guess I didn't understand your statement of the problem. If you know that the washer has gone through an entire cycle, and it is time to take out the RINSED dishes, yet the washer turns on when you do this, play with the door interlock and the door handle switches. If the cycle seems to have stopped, but you timed it from the beginning of a new cycle and it hasn't done all the steps, and it sprays when you open the door, then you may want to remove the timer motor and clean the contacts/ check for tine damage along with checking the door switches.
Aug 26, 2008 | Hobart Dishwashers
Washer won't cycle through...
The cycle timer may be defective and will need replaced. Hope this was helpful.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
