Check drain light is on and \i can't open the door
2 Suggested Answers
FaceTheFacts
  • 245 Answers
SOURCE: check drain light. machine won't open
You probably have a bad drain pump and the door lock wont release because of it. You're gonna need to replace the drain pump and if there's water in the machine, it's going to be a messy repair. I'd recommend a repair man on this job. If not order the drain pump for that model off the internet, take the top off, take the soap dispenser out, take the screw out, take the display board off carefully. Then take the front off, unscrew the door switch. on the door seal, use a flat head to take the ring out. If you got a drain at the bottom, take those screws out. Remove the door. There's going to be water everywhere if you didn't drain it out the front (if it's an option.) Replace the drain pump. (Kind of a little puzzle on every model.) Put it back together.
Posted on Jan 23, 2012
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Check drain light. machine won't open
Jan 23, 2012 | Miele W310 Front Load Washer
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
Control locked light is on.Can not start the cycle.
Open and close the door. The door has to be opened between consecutive wash cycles.
2. Check the door switch 3. If Door is Locked, Drain the Unit. 4. Check the wire harness connections. 5. Check the touch-pad/LED assembly.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Cherokee jeep internal lights not turning of draining battery also central locking not working having to do everthing from switch on door also alarm goes of everytime i open the door
one of the doors may not be properly closed. Check the spring by the door side, it may be weak. I recommend replacement. In the interim, use asoft object to pack this spring. the inner light will go of and battery will stop draining. Check all the fore doors to determine the one at fault. mostly driver or front passenger side.
Dec 30, 2009 | 2002 Jeep Grand Cherokee
Inside door lights stay on after engine is turned off
Check all doors for a sticking door open sense switch. Check all over-riding interior light activation switches are off. If all the above are ok, check for a sticking interior light relay.
Jun 10, 2009 | 1999 Chevrolet Suburban
Door locked light is staying on and door will not open
possible machine has not drained - this will prevent door opening.
put drain hose at floor level into a tray and drain that way then switch off at mains, wait 3 mins and see if door opens
Aug 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
