How can I repair the t con board - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Posted on Dec 28, 2016
How to change samsung tv t con board
Ken, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung LED TV Repair Con Board Replacement No Picture on Screen Image...
LCD TV Repair
Troubleshooting Distorted Video Con of LCD Panel TV Repair Vizio Sony...
Mar 22, 2016 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
Why does the screen turn white after 10 minutes?
Probably the t con board have problem. the power regulator ic on the tcon board make this problem. As ist an smd ic you have to go for a new tcon board, because its not possible to replace the ic with normal soldering irons. you need smd rework station for that purpose. And also on more thing in some tvs the t con board is integrated to the lcd panel. if so its not possible to replace only the t con board , you have go for a fresh lcd panel. it would be a costly repair. because the panel is the costliest part of the tv. Any why check the video to understand which one is the t con board. if you find one in yours then try to replace it with new one. hope your problem will solved
www.electro-medical.blogspot.com
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Nov 03, 2015 | Samsung Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
Sep 25, 2015 | RCA Televison & Video
My sanyo dp42849 screen still has a picture but it has turned white. What is the problem and how do I fix it?
Sep 25, 2015 | Sanyo Televison & Video
Vertical colored lines on entire screen, sound ok
Hi.
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Sanyo MODEL DP46848 Have this spot on front left of screen.Is this defect repairable. Any idea on how much to repair.Thanks
the cause it could be bad parts at the t-con board or has a loose connection going to the t-con board. before you come up with parts replacement you can re seat first the lvds cable going to the t-con board for the lcd panel. the t-con board is mounted underneath cover with metal shield.
Dec 04, 2012 | Televison & Video
Left half my my screen has different color bars running vertically down it
Your tv have problem with the T con board. T con board is one wich drives the pixels in the LCD panel. There is no repair possible with these boards. You have to replace the T con board. Normally you can find the t con board in the top centre or the bottom centre of the tv covered with metal cover or aluminium foil.
Here i have added the link for T con board you can fin the picture of the board in the link
Ajin
http://www.ebay.com/itm/Vizio-M550NV-T-Con-3655-0022-0147-4A-0170-2372-0024-/280719517500?pt=LH_DefaultDomain_0&hash=item415c2fe73c
Feb 09, 2012 | Vizio M550NV 55 in LCD HDTV
My Samsung LN52A550 has vertical lines in the middle and right side of the screen is black
This most likely a problem with the T-CON board.
If this set is under warranty you should return it to get it repaired/replaced by the seller.
IF YOU KNOW HOW TO WORK WITH ELECTRONICS REPAIR(board replacement ) or have a friend with knowledge/skill you can fix it.
Sometimes due to heating/cooling or contamination the connection pins on the T-CON board and cables do not make good contacts. The T-CON board is located in the center of the set.
After taking off the back cover and shield over the T-CON board carefully remove the flat cables connected to the T-CON board. I believe there are 4. The connectors have a lip on them to hold the cables so be careful.
Now reconnect the cables. Recheck the display now. If it has not corrected you can disconnect and reconnect again.
The very first solution I entered on fixya.com had essentially this same problem and solution.
If this does not solve the problem you can replace the T-CON board.
The T-CON board look something like;
Mar 02, 2011 | Samsung LN52A550 LCD TV
Picture has vertical lines (no picture)....what's wrong? It is less than 2 years old. can you help plrease?
Hi Matt, I know it's been awhile, but I'm making one last ditch effort to fully confirm everything you said. To start with, I replaced the T-Con Board, and it didn't correct the problem. My T-Con Board IS ATTACHED as shown in the picture, with the two ribbon connectors. Since it is connected, are you saying DON'T buy a main board, or are you saying since the T-Con is connected to BUY one? Thanks so much for all your help Matt, I wouldn't have been able to get this far without a good guy such as yourself. If I can't repair, I'm going to part out the boards anyway, if the front panel is bad. Please refer to the picture for clarification. Is it option 1, or 2?
1. T-Con Board attached, DO NOT buy main board.
2. T-Con Board attached, DO buy a main board.
Again, thanks so much for everything, I look forward to your final answer. Take care.
Tim
Feb 28, 2011 | Sony KDL-46VL160 46 in. HDTV TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
