How do I set up an access PIN number to watch recorded programmes on Sandisk ultra fit
fosg2000
  • 229 Answers
SOURCE: Recording and actually WATCHING the programmes I record
this feature its not from the TV is for DVR box, that storage the information on a hard drive inside, check your DVR model and number and google the proper manual for it
Posted on Mar 15, 2010
SOURCE: Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
Posted on May 08, 2010
SOURCE: Hi......... I have a Toppro
Press menu button, use the right arrow button to select the multimedia folder (the yellow one). In the multimedia menu use the down arrow to select RECORDINGS then press OK. The "Rec Service List " will appear. Highlight the program you want to watch using the up/down arrows then press OK.
Posted on Jun 15, 2011
  • 6771 Answers
SOURCE: Panasonic DMR-XS 350EBK DVD recorder PIN No unlock?
Contact Amazon since somebody set the pin number before the item was sent, the only other suggestion is check your owners manual for additional information, if no solution can be found and Amazon can't help, then it should be returned to them at their expence and they send a suitable exchange since warranty applies.
Posted on Mar 29, 2012
  • 1684 Answers
SOURCE: how to record on lg smart tv to usb
The USB device port is play only the TV does not have to capability to record to the USB stick.
Posted on Aug 22, 2012
Skycom pin help
Good day Mrs. Thomas
If you have never changed your PIN before and you are trying to find it, your default PIN which is issued to you when you join Sky, is the last four digits of your Sky viewing card number.
May 29, 2014 | Televison & Video
Mar 29, 2012 | Panasonic Televison & Video
Mar 15, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Hi, I need to watch scrammbled channel with my Digital Receiver
hi my name is mark, if you are on a C band dish, analog, digital or j-peg.some programmers that didnt scramble have started to and alot of them have updated to digital. you can try http://www.skyvision.com/ hope this helps. thanks for your question.
Mar 17, 2009 | Fortec Star Lifetime ULTRA
Sd card serial number
Open your computer and read it off the card
Jan 04, 2018 | SanDisk 1GB microSD Memory Card
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
